Quadzilla Commander
Old 03-29-2007, 01:44 PM
Pinksa's Avatar
Quadzilla Commander
Whats yalls opinion on the Commander for a '07 Dodge? What else will i need to install?
Old 03-29-2007, 02:01 PM
Luvnacumns's Avatar
Awesome monitor...
Shane
Old 03-29-2007, 03:55 PM
ollie32's Avatar
nice monitor, buttons suck!
Old 03-29-2007, 05:28 PM
ptgarcia's Avatar
Awesome monitor, buttons don't suck (they are fixed). Don't need anything else other than a drill and tap for the pyrometer to install.
Old 03-29-2007, 08:26 PM
JuzPlaneKrazy's Avatar
You need nothing else, worth every penny. just the fun to watch the numbers go up and down is enough
Old 03-29-2007, 09:21 PM
tslewisz's Avatar
+1 (and since we have a 10 char minimum I'll say "I agree!")
Old 03-29-2007, 10:23 PM
Pinksa's Avatar
Well I appreciate the input.. I need to save some coins!
Old 03-29-2007, 11:14 PM
rjm022's Avatar
i have had it since november
-that unit was replaced in december. since then i had a problem with correct tranny temp-readings. been told by quadzilla that having it read 104 degrees (devault setting) for 25 miles in the winter is normal. two weeks ago i replace my "hot tranny line' with the line that has the tranny probe. my tranny temp readings automatically changed- to real world temp readings. two days ago- the tranny temps readings stopped! won't move off of the default reading of 104 degrees. been in touch with quadzilla- tech now says it is because the "new tranny line" has a rubber portion in it , that it is grounding out!!!! which i know is not true! also, the top portion of the screen is getting dark and hazy. plus the cables to connect the commander to other modules-like the edge juice which i am running are not available yet-even though they said they would be at the first of the year!!!-january!!
norcaljr
13
08-05-2008 10:13 AM
stock03
11-09-2006 11:27 PM
ptgarcia
17
05-06-2006 06:39 PM
onesourceoil
04-12-2006 01:17 PM
Quick Reply: Quadzilla Commander
