Quad Race + Commander
Old Aug 28, 2007 | 12:42 PM
rodboy's Avatar
So I have a Quad race box that I had on my early 06 quad cab. I ordered the Commander about 3 weeks ago and got it all put on my new 07, basically the same truck just a Mega cab. I get everything all hooked up and it seems to be working, just not near as well as it did on my 06. Look at boost and it is hitting 30 - 32. OK, not as much as expecting, but ok. I also am noticing pretty high temps. I cannot even make a WOT run on level one without hitting the limit I have set which is 1400. Now I noticed this morning on the way to work all I can get it to do is spike maybe 17 psi. That is it even on level 3. Am I missing something here, or what? This thing ran great on my 06 with analog guages. could hit 40 on boost and yes EGT's were high but not this bad. Do I have a wire crossed or what? Any help would be appreciated guys.
Old Aug 28, 2007 | 01:46 PM
ptgarcia's Avatar
Apparently late '06 and '07 5.9 trucks have different ECM programming or something than the earlier '06 trucks. This has caused complete melt-down when using a particular power adder. It's just speculation, but your issues may be related.
Old Aug 28, 2007 | 01:53 PM
06CTDforAU's Avatar
That's what I was thinking but I don't know for sure. Hope you get it figured out; the Quad Race is a good box.
Old Aug 28, 2007 | 02:26 PM
shortbed rv's Avatar
What power level is the Commander set on? Not the race box but on the Commander.
Old Aug 28, 2007 | 04:24 PM
rodboy's Avatar
The Commander to my knowledge controls the Race box and that is the only level that you can set. I know you can change what modules you can control, but to my knowledge that is the only thing you can control the levels on.
Old Aug 28, 2007 | 04:39 PM
ptgarcia's Avatar
If it's installed correctly you should be able to adjust the box to one of 4 power levels: 0, 1, 2 or 3 via the Commander.
Old Aug 28, 2007 | 05:44 PM
ACECTD's Avatar
I think something is messed up in the install. I have an 07 MegaCab and on level 1 I can barely get over 1200 on my EGT. I do have a intake and removed the muffler but don't think there is THAT much of a difference.
Old Aug 28, 2007 | 06:21 PM
gtaj4's Avatar
Call Quad Tech support and ask Jeremy. He'll be able to tell you right away what is wrong.
Old Aug 28, 2007 | 06:58 PM
If you are just fooling around try unpluging the box from the Commander. Then test drive the truck.
Old Aug 28, 2007 | 07:14 PM
qzilla's Avatar
Make sure the COmmander is not accidentally set to the XZT box. That will make everything sort of backwards!!!
Old Aug 28, 2007 | 08:07 PM
rodboy's Avatar
I disconnected the Race module and put in the bypass and now I am only getting 12 PSI of boost and it is very, very sluggish. It is like something is holding it back and it is not getting enough air. Also before I took the race module off on level 3 I was making alot of smoke, more than my 06 ever did. Is this thing holding my wastegate open or something? I have a AFE ProGuard7 Super Stock filter and I have the muffler delete kit from Geno's Garage, but I still have the cat and resonator. I know it can get hot on level 3 but even on level 2 I am at or over 1400 before I get to 6th gear and it starts to defuel. I know I am not getting enough airflow for some reason but I can't figure out why. It seems like the wastegate is stuck open because I can hear the turbo whine pretty clear. I still have the silencer ring installed and all of the guts in the stock intake also, just haven't gotten around to taking that stuff out yet.
Quad, I checked everything and it is set up right. 04.5 - 07 truck and the std/race module.
Thanks guys, not sure what is going on but I don't want to burn this thing up it only has 15000 miles on it so far.
Old Aug 28, 2007 | 08:20 PM
ptgarcia's Avatar
Check for a boost leak around the intercooler boots.
Old Aug 28, 2007 | 08:41 PM
deereguy07's Avatar
I've got a friend with an 07 3500 on stock his would hit 1300 empty just truck. He melted #4 and 6 pistons about a month ago with just a 100hp ts. Another friend that worked for dodge told me that the 07's were a hotter truck from factory.
Old Aug 28, 2007 | 09:59 PM
qzilla's Avatar
Bingo, that is the info I needed.
99% positive it has a faulty relief valve. I can almost guarantee it. Get it swapped out and you will be in business!
Old Aug 29, 2007 | 07:51 AM
rodboy's Avatar
Thanks alot. I will get it changed out and see what happens. This is why I bought a Quadzilla product. Its all about the Customer Service, I don't care what you are doing. I guess some people just don't get it.
Thanks again Quad, I really appreciate it.
BigJohnston
Feb 7, 2008 06:14 AM
HDBeauty
Apr 14, 2007 11:34 PM
stock03
Nov 9, 2006 11:27 PM
carcrz
Nov 9, 2006 01:26 PM
LinearX
Jun 14, 2005 04:48 PM
