pyrometer gauge has stop working
Old 04-30-2012, 05:58 PM
Logan McD's Avatar
well my pyro gauge has stop showing the the right temp it kinda looks like it is shorting out but it work for over a year what would be the first thing to check out or replace on the hole setup like any ideas
Old 05-01-2012, 07:14 AM
JEMGTX's Avatar
When mine stopped working, it was the "probe" I had to replace.
Old 05-01-2012, 10:02 AM
infidel's Avatar
Check electrical connections first
Old 05-01-2012, 12:31 PM
jhenson's Avatar
Electrical connections should be checked first to rule out any loose wires. Then buy yourself a new probe. You say it's not reading right so I assume the stepper motor in the guage itself is still functioning.
By not reading right, what exactly is it doing.....a few hundred degrees off? If so more than likely the probe is bad. Is the guage reading at all? Any extra fueling? Clogged air filter?
Best guess is that the probe needs to be replaced.
Old 05-01-2012, 01:06 PM
Logan McD's Avatar
well when it started it was about 300 degrees less than what it was then it started not not show any temp at all. but it matters on the day what it does
Old 05-01-2012, 01:16 PM
jhenson's Avatar
Definitely sounds like a bad probe to me.
old green
06-12-2008 05:54 PM
slivertruck
25
11-08-2006 08:35 PM
royta
11-06-2006 08:19 AM
ralphie
09-08-2005 04:11 PM
dodgeboy59td
01-29-2003 08:11 PM
Quick Reply: pyrometer gauge has stop working
