Pusher Pumps in the Outback
Old 05-31-2005, 07:09 AM
crobtex's Avatar
How do the frame mounted pumps hold up to off road driving? I do a fair amount of driving on gravel roads, and have been know to drive thru pastures with high grass and brush. I'm considering installing one, but am a little concerned about it being exposed to the elements.
Old 05-31-2005, 08:14 AM
AlpineRAM's Avatar
If you mount it inside the frame so that it doesn't stick out and you make a small shield of sheetmetal it's rather sturdy.
Old 05-31-2005, 10:34 AM
RowJ's Avatar
Re: Pusher Pumps in the Outback
Originally posted by crobtex
How do the frame mounted pumps hold up to off road driving...gravel roads, and have been know to drive thru pastures with high grass and brush.
I do 50% of my work miles (not to mention hunting miles) on County Roads and gravel roads. Have had full FASS for over 15,000 miles with no problems. In fact, looked it over this weekend and found NO big nicks or any dents.
Long beds seem to handle debris that far back better than the short beds. We were able to tuck my FASS up pretty high by welding the bracket to the side frame rail support....bottom of filters is even with bottom of frame (see gallery).
FASS II is even better protected....and cheaper.
RJ
Old 05-31-2005, 05:44 PM
BigBlue's Avatar
I've got mine mounted on the outside of the frame rail and actually dropped it on a ledge and slammed the pump into it and it has held up fine.
Old 05-31-2005, 06:17 PM
crobtex's Avatar
I guess they are tougher then I thought.
DieselBoy20
06-04-2008 11:31 PM
04ctd
11-20-2006 09:25 AM
Quick Reply: Pusher Pumps in the Outback
