Problems with Edge Juice box anyone?
Old Jun 30, 2005 | 05:32 PM
Mr. Dog's Avatar
Question Problems with Edge Juice box anyone?
My local diesel shop guy says he won't install the sdge juice box because of problems he's had ( or heard about) with cracked injectors.
Has anyone had any problems with the edge juice box?
He is pushing the box made by BD.
I was pretty sold on getting the juice w attitude until I talked to him.
Any opinions welcome.
Paul
Old Jun 30, 2005 | 06:13 PM
RamWheelsBy4's Avatar
I currently have the Edge HOT Juice/Attitude installed. Had the standard Juice installed before that. I have had no problems or issues with install, codes or operation.
Because I have had my computer reprogrammed for my larger tire size the Attitude transmission monitoring does not function for me. This is not a real problem for me since I have had TC and Transmission completely upgraded for racing.
I have tested a Quad XZillaraider Race box with no problems or issues at all.
I have also had a DR Performance Stage II pressure box that did what it said, but the high fuel pressure made the truck idle and run very rough. It may have also contributed to the demise of #6 injector.
Old Jun 30, 2005 | 06:48 PM
Car_nut57's Avatar
We have not seen any problems at all with the Edge Juice.
Old Jun 30, 2005 | 07:00 PM
hokey's Avatar
Thumbs up
6,000 miles on an edge juice with no problems at all have the hot juice now and works great.
Old Jun 30, 2005 | 07:17 PM
Mr. Dog's Avatar
Thanks Guys
wuts the difference between the jiuice and the hot juice?
Old Jun 30, 2005 | 07:37 PM
bama's Avatar
i think he probably has the juice confused with the ez box.he has probably heard some of the high pressure problems that don m has been talking about with the ez................bama
Old Jun 30, 2005 | 09:16 PM
hokey's Avatar
Originally posted by Mr. Dog
Thanks Guys
The standard juice is 25-40-60-80-100hp hot juice is 40-60-80-100-180hp.
have used the quadzilla xzillaraider race and the TS ramifier and liked them both.
i love pressure but just a little shy of it due to the already relativly high pressures of the 05's.
the Edge juice is great, a quality unit. I have never tried the TST PMCR.
good Luck
Old Jun 30, 2005 | 11:36 PM
HOHN's Avatar
Problems with the Edge juice box??
TRY SNAPPLE INSTEAD!!
Or was it Capri Sun?
<<zing>>
jlh
Old Jul 3, 2005 | 11:40 PM
lightening ram's Avatar
zero problems also works awesome even stacked with the competitors boxes
Old Jul 4, 2005 | 10:46 AM
RAM-RED's Avatar
My .02
I don't care for any pressure boxes at all! Think about it for a minute, we went from injectors poping at pressures in the thousands and we were getting great HP and TRQ out of these little 5.9 cummins, but now we have increased these CRail to 20,000+ psi, do you think we need any more pressure???? I would recommend the TST product Powermax CR, these guys have worked for cummins before they desinged these aftermarket products for us. The PMCR does not increase pressure it just changes the duration of the pulse of fuel and changes the timing to better use the fuel you are using (the smart way to truly get more HP and TRQ). The pressure boxes is the easiest way for a aftermarket group to give you small increase but pushes the pressure to desctrutive levels, why do you need more pressure???? Think about it ??? TST has really done it right, they have gone where others should go to better give us a choice (maybe some of the other are not smart enough to figure it out).
RAM-RED
I have a 03 with a TST PMCR and 52000 miles going great.
Old Jul 5, 2005 | 01:35 AM
Big Bob's Avatar
I just want to claify that the 04.5-05 Juice does not do pressure. It only does timing and duration.
Old Jul 5, 2005 | 10:37 AM
Mark Craig's Avatar
Mr. Dog,
Sounds like whoever you're dealing with is not an Edge fan, or maybe he is cautious on the EZ as someone else mentioned. We have sold literally 100's of the Juice/Attitudes with little to 0 problems, just an occassional DOA out of the box.
Best overall product with the gauges and de fuel functions built in the safest too! Call us if you have any questions we'll be glad to help you.
Mark @ DPPI
Old Jul 5, 2005 | 05:19 PM
Mr. Dog's Avatar
I think yo guys are probably right about the ez mix up.
Thanks for everyone's input.
Havic801
Nov 16, 2011 02:34 PM
MrSuzuki
Aug 25, 2009 07:22 AM
razor6
22
Jan 20, 2006 03:43 PM
djcheez
Oct 15, 2005 04:13 PM
alltork
May 14, 2004 02:13 PM
