power steering
Old 11-19-2010, 08:23 AM
Exekiel69's Avatar
power steering
This is a question for My 4bt but I believe it is almost the same as the one I have on the 6bt minus the VP.
There is some nasty very thin fluid in it right now (don't blame Me I just bought it) and I want to drain it and refill. I bought some 3qt of ps fluid I was thinking I would start the engine, disconnect the low pressure house coming from the ps pump, let the fluid out and start filling it with ps fluid until it came out clean then put the hose back and fill it all the way. Any other way to get this done? Any of You add Lucas ps additive to theirs?
Thank You.
Old 11-19-2010, 10:44 AM
ppiggppenn's Avatar
I'm watching this thread with interest, ... my PS is barely detectable, mostly "armstrong" steering. What solutions you find may help mine too, ...
Old 11-19-2010, 11:13 AM
james1's Avatar
Smile old threads are your friends...
The 10th post in this old thread details one means of flushing your PS fluid:
https://www.dieseltruckresource.com/...steering+fluid
Old 11-19-2010, 11:47 AM
Exekiel69's Avatar
Excellent, I thought about jacking it up but this seals the deal.
Thank You.
Old 11-19-2010, 12:29 PM
jesussaves's Avatar
ill trade you your 4bt PS assembly for my 6bt VP/PS assembly
Old 11-19-2010, 12:39 PM
Gots_a_sol's Avatar
I'll make that offer too. and I'll drive over to you to do it
Old 11-19-2010, 01:49 PM
Exekiel69's Avatar
Why is that? They look similar to Me.
Old 11-19-2010, 01:53 PM
jesussaves's Avatar
Originally Posted by Exekiel69
Why is that? They look the similar to Me.
They are the same.
I put my cummins in a ford and i dont need the VP. I thought you might need a vacuum system
Old 11-19-2010, 01:56 PM
Exekiel69's Avatar
This one is in a GMC with hydroboost and I also put a cummins in My ford and although I have a VP on it now I will remove it and use a psd electric VP since I also put a hydroboost on that truck and I only need vacuum for the vent controls. Thank You.
Old 11-19-2010, 02:03 PM
jesussaves's Avatar
If you find a good 4bt pump let me know, for some reason it bothers me to have unecessarry stuff on my truck?
Old 11-19-2010, 02:22 PM
Gots_a_sol's Avatar
Same here. And people seem to be proud of those 4bt pumps also
Old 11-19-2010, 02:31 PM
jesussaves's Avatar
do you know what vehicle you would search under car -part .com for a 4bt V/P
Old 11-19-2010, 04:10 PM
Exekiel69's Avatar
Heck that I don't know, Mine is on My step van but I have two stories one that it came originally with a 292 392 engine and they swapped the 4bt and the previous owner said it came originally with that engine, I thought he was full of edit but when I ordered some parts for it the guy at cummins told Me it was manufactured in 1986 and the van is a 1987.
Old 11-20-2010, 08:37 PM
Exekiel69's Avatar
Well I flushed all the fluid out and it smelled like ATF a little strong too. I filled it with valvoline steering fluid and seems to work just the same, I just feel better that is it new fluid and the appropriate type too.
Thank You all.
Old 11-21-2010, 08:18 AM
blackimpala's Avatar
Have you tried this?
http://westtexasoffroad.homestead.co...rsteering.html
Floyd
tony99
04-09-2014 08:25 AM
Dean Snow
11-14-2007 04:36 PM
DodgeCowboy
08-28-2006 08:57 PM
RAK GUY
04-05-2003 10:28 PM
Garz
11-17-2002 02:02 PM
Quick Reply: power steering
