Power Problems
Old Feb 13, 2009 | 10:03 AM
cody459's Avatar
Power Problems
I have a 2006 3500 dually and with the truck running and in nuetral if you rev the motor up then let off the pedal the motor stays reved up for a couple of seconds then slowly idle's back down, could this be the FCA (fuel control accuator) sensor? Also truck doesn't have much power driving down the road. I think the same issue is causing both these problems, and I don't think its a injector problem because just had #4-6 replaced when dodge told me that was the problem and it still does it.
Old Feb 13, 2009 | 12:16 PM
bradler's Avatar
any codes? fca problems can throw an 0251 code.
Old Feb 13, 2009 | 12:46 PM
cody459's Avatar
It hasn't put out any codes.
Old Feb 13, 2009 | 01:23 PM
bradler's Avatar
maybe do a search on reseting the aps (accelerator position sensor i think). i remember other threads from others having similar problems...
Old Feb 13, 2009 | 01:41 PM
cody459's Avatar
Where is the APS located at?
Old Feb 13, 2009 | 01:57 PM
cody459's Avatar
I failed to mention one other thing, and that is when you unplug the turbo sensor located on the head and rev the engine up it idles back down smoothly, so I replaced that sensor but when pluged back in it still does the same thing.
DJ Turbo.
Oct 13, 2011 09:11 PM
staken
Mar 5, 2008 07:41 PM
95 Dodge
Jul 2, 2006 03:28 PM
Tintickid
Oct 31, 2003 09:51 AM
Paws
May 13, 2003 09:08 PM
