Pics of twins with ht3b only
Old Jan 22, 2007 | 06:12 PM
aggiehorsepower's Avatar
I just want to see some pictures of a twins setup with hx35 and ht3b only. I am trying to see how to fabricate some pipes.
Thanks guys
Old Jan 22, 2007 | 08:26 PM
BCB's Avatar
BCB
how about HX35/40 over s400 twins?
Old Jan 22, 2007 | 09:23 PM
TxDiesel007's Avatar
Thanks guys
www.powerbypoole.com
has a 35/3b combo in the twins section, and PDR webpage has the twins setup with the 3B..
Rick
Old Jan 22, 2007 | 09:36 PM
ratsun's Avatar
This is the best I have right now
As mentioned PDR used to have a nice one on their site.
Old Jan 22, 2007 | 10:01 PM
Mike Holmen's Avatar
The Guru
My engine is a little dirtier and the air filter has been swished from my battery. Some of the paint has been rubbed off. Nice 12v pic. I was told by PDR you can change back and forth between the 35 and 40. The air tube is the same but the hot exhaust downtube is different. I planning on getting a 35 just to see how much better it works with my smaller injectors. I've also burnt my firewall pads and some of my electric wires. Melted off my pyro wire. She gets a little toasty at times.
Old Jan 22, 2007 | 10:11 PM
ratsun's Avatar
Man this ones a mess compared to my 24v, it was really clean and tidy
Mike I think you will be amazed at the difference with the 35 if your sticks aren't to big for it.
Old Jan 23, 2007 | 06:13 AM
RonA's Avatar
An S300 will fit with a just a hotpipe change also. The 35 comes on quick but goes a bit flat on the top. Usually runs a tiny bit cooler at hiway speed.
Ron
Old Jan 23, 2007 | 03:23 PM
Could you show some pics of the bottom turbo?
Old Jan 23, 2007 | 03:29 PM
74dart's Avatar
If you go to the member picture gallery and do a search for twins you will get around 12 pages of them. Thier are some good pictures in there of people who fabricated there own piping system and alot of good pics. I have looked at all of them.
Old Jan 28, 2007 | 09:45 PM
The Guru
I'm asking PDR to findout if my air tubes would work with a S300. I know that the hotpipe is different. I really don't want a 35 as I think that a s300 turbo would move the same air as my 40 and would spool similar to a 35. I've been also think about just dumping the twins and buying someone else's just to see if they are better or not. MY 0-10psi spool-up is so sluggish but after that its a great ride. My pyro quit working about 4 months ago and I've been to lazy to fix it.
dodgediesel
ABDTR #5
Oct 18, 2011 09:22 PM
dodgediesel
ABDTR #5
496
Oct 16, 2011 04:33 PM
dodgediesel
17
Apr 5, 2011 11:21 AM
Stock 02
28
Sep 24, 2006 11:09 AM
1ST GEN.
Jan 13, 2005 03:22 PM
