Phantom no power to cig lighter
Old 12-24-2008, 08:49 AM
VADSLRAM's Avatar
I've got a strange problem!
I put a wreath on the front of my truck like every year but this year I ran a small set of lights on it to an inverter plugged into the cig lighter outlet in the cab. ( I get a lot of smiles out of it)
But the other morning I started it and the wreath lit and went out. I checked the fuses all are good, If I plug it into the 12v power outlet everything works fine. I put a meter on the cig lighter and it shows 12v but there isn't enough current to even light the LED on my car phone charger
I figure it's got to be a bad/incomplete connection somewhere between the fuse and dash but I've no intent on tearing apart the dash while it's still cold out.
Anyone else have this happen?
Merry Christmas, Happy Chanukah, Joyous Kwanza, Gauisus Saturnalia, Feliz Navidad, Nadolig LLawen, Veseloho Vam Rizdva!, Maligayang Pasko at Manigong Bagong Taon, Bon Natali, Nollaig chridheil huibh, Boas Festas, Sheng Dan Kuai Le, Gleđileg Jól, God Jul and have a Happy New Year!!!!
(now you know it in Latin, Spanish, Welsh, Ukrainian, Tagolig, Italian, Scots Gaelic, Portuguese, Mandarin, Icelandic, and Swedish but don't try to say it or you'll break your tongue!)
Old 12-24-2008, 09:00 AM
TIMMY22's Avatar
Could be a bad ground.
Old 12-24-2008, 02:12 PM
Busboy's Avatar
If you are a smoker and use the lighter for it's intended purpose then the pos + connection inside the lighter socket gets badly corroded. You can clean off the corrosion just be careful not to touch the sides or it will ground out.
slickr1
05-30-2012 08:27 AM
txdutchman
02-26-2010 09:45 PM
jon05ctd
09-05-2006 03:56 PM
03CTDCO
02-28-2005 05:35 PM
Maccandy
07-13-2004 11:10 AM
Quick Reply: Phantom no power to cig lighter
