Part # for vacuum pump shaft seal??
Old 04-23-2007, 06:48 PM
greenwing's Avatar
I am sort of in a tight spot for money right now otherwise I would just buy the repair kit from www.fixinrams.com but I'm a mechanic and think I can tackle the job, I just need the part #'s of the shaft seal and any other seals needed. Is the oil supply line on the bottom of the vp a JIC fitting? I saw a thread on here a while back that had the napa part# for the shaft seal but I can't seem to find it back.
Thanks,
-Ryan
Old 04-23-2007, 08:29 PM
jrs_dodge_diesel's Avatar
The seal is a double lip vitton rubber seal that can be found at a hydraulics shop. I don't remember what the dimensions on it are though.
I did the fixinrams repair. I paid ~$60 and got the seal, several O-rings, assembly grease, several presses for getting the seals/parts in and out and a good video on how to repair it.
I don't remember what size the oil line fitting is, but I remember using an open end wrench on it.
Old 04-23-2007, 10:39 PM
johnh's Avatar
Thanks,
-Ryan
this seal kit is from cummins for less than 10.00 4089742
Old 04-24-2007, 10:40 PM
greenwing's Avatar
Is there a mopar # that crosses to that cummins # or do you have to get it from cummins? Is there any online vendor for cummins? If not I can probably find it maybe even through work.
Old 04-25-2007, 10:10 AM
b4wheeler's Avatar
Check this link. $15 + $6 for the o-rings, seal and gasket.......
http://hectorwithinjectors.com/DODGEDIESELPRODUCTS.aspx
This guy has a 100% rating on E-bay, so I assume he is honest and trustworthy.
Old 04-25-2007, 12:35 PM
johnh's Avatar
that is the same kit i got from cummins
Old 04-25-2007, 12:43 PM
b4wheeler's Avatar
I posted this because he was looking for an online source for the kit....
Not everyone has access to a Cummins dealer like you and I......
Old 04-25-2007, 04:01 PM
greenwing's Avatar
Thanks guys
Old 04-25-2007, 08:48 PM
Break Away's Avatar
The kit from Cummins has instructions included...
jimbo486
05-08-2016 06:07 PM
ARbowhunter7
03-24-2012 11:03 PM
SeanB23
06-21-2009 07:18 AM
jsimpson
09-04-2003 09:39 PM
yomitch
04-21-2003 06:28 PM
Quick Reply: Part # for vacuum pump shaft seal??
