Parking Brake Problem?
I just bought my 2002 Dodge 3500 DWR with the Disc Brakes, I have noticed that sometimes it will start to roll after the parking brake has been set. Where should I look first for problem? ANy tips would be greatly appreciated.
The parking brake is adjustable. The rear disc have a set of drum brake inside the hub area. On the backside of the hub... Look careful you will find a rubber plug in the hub area on both sides. You need to turn the star wheel with a flat blader screwdriver to adjust them.
Fairly easy to do...
Originally posted by Mopar1973man
The parking brake is adjustable. The rear disc have a set of drum brakes inside the hub area. On the backside of the hub...
What he said.
There is a dust/rock shield in the way, so it's hard to actually see them.
phox
Cowboy_Customs
07-10-2009 05:11 PM
RamDan03
11-09-2003 10:26 AM
