Parking Brake Problem?
I just bought my 2002 Dodge 3500 DWR with the Disc Brakes, I have noticed that sometimes it will start to roll after the parking brake has been set. Where should I look first for problem? ANy tips would be greatly appreciated.
The parking brake is adjustable. The rear disc have a set of drum brake inside the hub area. On the backside of the hub... Look careful you will find a rubber plug in the hub area on both sides. You need to turn the star wheel with a flat blader screwdriver to adjust them.
Fairly easy to do...:D |
Well I crawled under there and it is disc brakes on the rear too. So does it adjust the same way? Thanks for any help.
I'm posting a pic of the adjustment hole on the rear axle... It will be in my picture gallery...
Originally posted by Mopar1973man The parking brake is adjustable. The rear disc have a set of drum brakes inside the hub area. On the backside of the hub... What he said. There is a dust/rock shield in the way, so it's hard to actually see them. phox |
Ok thanks guys:D
https://www.dieseltruckresource.com/...CF2087-med.JPG
Here is the pic of the hole... Driver side rear axle on the top side of the tube... Phox, Thanx for the quick add to the photo gallery! :D |
