over drive vs. torque converter lock up
Old 07-02-2007, 08:49 PM
firetoy's Avatar
i have a 92 cummins with the 727 if i hit the over drive button off does that mean the tc is locked up?
Old 07-02-2007, 09:41 PM
mhuppertz's Avatar
No, they are not the same (although it kinda feels the same though). Lockup is when a clutch in the torque converter engages, causing a direct drive from the engine to the trans input shaft. It's that same as letting the clutch out on a standard trans. Overdrive is when the output shaft of the trans spins faster than the input shaft. The later autos have lockup and overdrive.
Does this help?
Old 07-03-2007, 07:14 AM
firetoy's Avatar
yeah thats helps. is there anyway to get the tc to lock up?
Old 07-03-2007, 08:05 AM
mhuppertz's Avatar
Not with your 727. You'll have to go with a later model that has provisions for a lockup because lockup trannys are designed that way. If you blow up the 727 you might want to switch to a 46RE or 47RE lockup model. The auto guys will be able to guide you on this.
Mark
reference: http://www.transmissioncenter.net/dodge.htm
Old 07-03-2007, 10:05 AM
Cowboy_Customs's Avatar
The early A518 is a non-lockup transmission, but with overdrive, the 94-95 47RH (hydrolic), and 96+ 47RE (electronic) are lockup overdrive trannies.
By simply pushing the OD button in your rig, your just downshifting.
U have to switch to a different transmission to get lockup, and more lesctronics I believe as well, the 94+ trannies have like 3 plugs, versus 2 plugs on the A518.
Old 07-03-2007, 11:20 AM
firetoy's Avatar
well when i burn it up then a will do a swap. in the mean time i will install another tranny cooler.
Old 07-03-2007, 11:31 AM
mhuppertz's Avatar
Leave the tranny cooler off and it will burn up faster!
dieselman24
41
07-21-2012 09:34 PM
bigfoot
08-14-2004 02:22 PM
mr T
05-15-2004 09:41 PM
chrismez
08-28-2003 07:19 AM
Quick Reply: over drive vs. torque converter lock up
