who is over 600hp with an I.I. stage 2 pump?
Old Nov 17, 2007 | 08:41 PM
jlibert's Avatar
#2 only. I've seen numerous trucks over 600 with a floor-it pump, who's doing it with an industrial pump. thanks.
Old Nov 17, 2007 | 08:52 PM
35" 05''s Avatar
630 stock pump
Old Nov 17, 2007 | 09:00 PM
lmills's Avatar
made over 600 HP with a stocker on fuel 600 Hp on a stage 2 should be easy.
Old Nov 17, 2007 | 10:05 PM
Little03's Avatar
Morkable Made over 600hp with a II stage 2 pump last year.
Nick.
Old Nov 17, 2007 | 10:46 PM
CReed's Avatar
Greg is claiming around 9XX on fuel alone with stage 2 II pump on diesel power x last time i talked with him.
Old Nov 18, 2007 | 01:07 AM
jlibert's Avatar
Originally Posted by 35" 05'
630 stock pump
how much boost did you see on the dyno? what kind of dyno? thanks
Old Nov 18, 2007 | 01:11 AM
sliqwille04's Avatar
not to get off topic, but how do you like the silver bullet. mine should be delivered on monday.
Old Nov 18, 2007 | 11:05 AM
ramtd02's Avatar
670 with the II Stage 3 pump.....26K rail pressure
Old Nov 18, 2007 | 01:43 PM
35" 05''s Avatar
48lbs. could turn it up a bit but Im playin it safe.
Old Nov 18, 2007 | 02:09 PM
jlibert's Avatar
is 48psi the same max you see on the street? I regularly see 55 psi on the street but can't make more than 42 psi on the rollers
Old Nov 18, 2007 | 02:15 PM
jlibert's Avatar
I really like it. It does everything I need it to do. (tow 10k, max egt at wot about 1350). I've barked it 100 times and it's still holding on. Keep in mind that I have nothing to compare it to.
Old Nov 18, 2007 | 03:05 PM
Chris Blevins's Avatar
I've done 668 on Floor it's dyno with my II pump.
rock crawler
31
Jun 26, 2009 11:27 AM
kwa1207
17
Jan 9, 2008 11:49 AM
jlibert
18
Aug 14, 2007 08:46 AM
timb
Aug 19, 2005 10:16 PM
bigfoot
Aug 14, 2004 02:22 PM
