Opinions on repaint
Old May 1, 2009 | 02:02 PM
93-12Smoke's Avatar
Opinions on repaint
I am planning on having the Goat repainted the end of this summer and I am having problems deciding how to have it done. I am going to stick with Red but am seriously considering having the rockers sprayed with bed liner. I had this done on my previous truck (Silver Tacoma w/ sprayed bottom 6”) due to the amount of rock chips from the mud tires. On the Tacoma I had it sprayed up to the rubber molding and in my opinion I think it made the truck look good. If I have the Dodge done this way it too will be black bed liner due to the fact the people I have talked to about the colored bed liner say it fades real bad and the red will turn to pink. My dilemma is if I have it sprayed up to the trim then I think it will be too much. I could take the trim off and not go to high but then I don’t have that trim to protect the new paint from the ever so nice people at Wal-Mart who use your car door as a door stop for their car door. Any thoughts? I attached a photo of the tacoma incase someone is not following what I am talking about.
Old May 1, 2009 | 02:06 PM
I like the idea IMO.
I always liked silver/red. But I think black on the bottom would look nicer up to the lower body line because the black trim would make the silver rhino look weird.
Old May 1, 2009 | 02:10 PM
93-12Smoke's Avatar
Yeah if I do it, it will be black bed liner.
Old May 1, 2009 | 04:54 PM
RollinCoalSmoke's Avatar
I did my 93 with the black bedliner, the truck is white. I put a coat of sealer over the whole truck and was worried that the black would show thru the white. Prior to or while wet sanding the truck I sanded the bedliner just like I did the rest of the truck then i went over the whole thing again with a scotchbrite pad and rubbed the daylights outta the bedliner then painted the whole truck brite white. The paint is only 3 weeks old but it's not bleeding thru yet. Hope it doesn't but it might. Good luck on however you do it.
Old May 1, 2009 | 06:41 PM
EatMySmoke's Avatar
Found a truck that matches your idea. Hope this helps.
Dawson
Old May 1, 2009 | 08:28 PM
DU.DP.'s Avatar
go with the pic that style there! that is an amazing looking truck!
Old May 1, 2009 | 11:48 PM
93-12Smoke's Avatar
Yeah that looks awesome. Thanks!
Old May 2, 2009 | 01:53 AM
xjjones's Avatar
they do make some colored bed liners don't know if they fad or not
Old May 3, 2009 | 03:45 PM
93-12Smoke's Avatar
yeah I looked into the colored liners but I was told the red has a tendancy to fade to pink.
Old May 3, 2009 | 06:02 PM
mjozefow's Avatar
What about clear 3M film? That way you get protection that is removable.
I have Line-x in my bed. The great thing is that it will never come off no matter what. The bad part is that it will never come off no matter what.
If I were buying a truck, I would prefer that any mods the PO made would be able to be taken off. Might impact your resale value.
My .02.
Edit: Maybe even vinyl graphics of some sort?
Old May 4, 2009 | 07:57 AM
93-12Smoke's Avatar
I plan to drive this into the ground and then make a mudder out of it when it is no longer able to complete its task of pulling the current mudder. So resale is no concern.
Old May 4, 2009 | 05:48 PM
b.seaman's Avatar
i did on my '92 and i have the dark forest green above the trim. The only thing i don't like about it is how course it is. Body shops have actual chip guard which is less aggressive than actual bed liner, if i was going to do it again that is what i would use.
Haulin_in_Dixie
Jul 7, 2023 02:13 PM
InfernoMega06
May 28, 2012 05:28 PM
manganos
Feb 25, 2006 04:56 PM
bulthisl
Mar 22, 2003 07:01 AM
