OneTun I need your help or anyone with a Kore Chase
Old 04-05-2007, 07:00 PM
CDoskocil9's Avatar
OneTun or anyone else with a Kore Chase could you please measure the amount of lift the Kore Chase gave you.... I guess most accurate would be center of wheel to fender.... Or mirror to ground.... I think mine is shrinking $3000 for a shrinking lift............
Old 04-05-2007, 08:05 PM
trik396's Avatar
If I head out to the garage again tonite, I'll measure. If not, then tomorrow.
Old 04-06-2007, 12:52 PM
CDoskocil9's Avatar
Thanks Trik
Old 04-06-2007, 01:39 PM
trik396's Avatar
Measured at lunch time. 27.5" passenger side. 27.75" driver side. This is from dead center of wheel (took off cap), however it is using a tape measure and I had to bend it slightly over the curve of the tires' sidewall. If I had a couple of levels and an extra set of hands I could've been more accurate.
Can you let me know what yours measures also?
Old 04-06-2007, 02:41 PM
bob4x4's Avatar
It is much easier and more accurate to measure from the pinch weld to the ground,nothing in the way.
Bob
Old 04-06-2007, 03:10 PM
trik396's Avatar
Different tire size will throw the number off...
Old 04-06-2007, 05:27 PM
CDoskocil9's Avatar
Thanks Trik I will get a measurement tomorrow.....
Old 04-06-2007, 05:59 PM
CDoskocil9's Avatar
Trik I got 27.5 on both sides......
DirtEater
12-09-2005 11:36 AM
HreCmesTrbl
11-27-2005 09:33 AM
HreCmesTrbl
11-12-2005 05:30 PM
CTDjeeperman
05-06-2005 02:13 PM
Lightman
44
02-01-2005 11:23 AM
Quick Reply: OneTun I need your help or anyone with a Kore Chase
