OneTun I need your help or anyone with a Kore Chase
OneTun or anyone else with a Kore Chase could you please measure the amount of lift the Kore Chase gave you.... I guess most accurate would be center of wheel to fender.... Or mirror to ground.... I think mine is shrinking[verymad] $3000 for a shrinking lift............
If I head out to the garage again tonite, I'll measure. If not, then tomorrow.
Thanks Trik
Measured at lunch time. 27.5" passenger side. 27.75" driver side. This is from dead center of wheel (took off cap), however it is using a tape measure and I had to bend it slightly over the curve of the tires' sidewall. If I had a couple of levels and an extra set of hands I could've been more accurate.
Can you let me know what yours measures also? |
It is much easier and more accurate to measure from the pinch weld to the ground,nothing in the way.
Bob |
Different tire size will throw the number off...
Thanks Trik I will get a measurement tomorrow.....
Trik I got 27.5 on both sides......
