OK.... I ran the codes...Can you help?
Old Aug 10, 2008 | 02:17 PM
JimonaWing's Avatar
It's me again with the '99 that stopped on the road yesterday. I rented a code reader from Autozone and here is what I have found:
P1688
P0252
What do you think?
Thanks,
Jim
Old Aug 10, 2008 | 03:26 PM
Zeus1987's Avatar
P1688 is Internal Fuel Injection Pump Controller Failure
P0252 Injection Pump Fuel Metering Control
to me it sounds like it is new pump time .... sorry
Old Aug 10, 2008 | 05:29 PM
JimonaWing's Avatar
OK.... so now what's next? Where is the best place to get the pump?
Is there anything else that I should be doing? How about the lift pump? It seems to be pumping OK.
Should I be considering a fuel pressure gauge at this time?
Thanks,
Jim
Old Aug 10, 2008 | 06:30 PM
Zeus1987's Avatar
i have heard alot of good things about blue chip's VP44's. I would definitely get a fuel pressure gauge or at the very least a 5 psi pressure switch that is hooked up to a LED warning light. the stock lift pump is junk replace it as soon as funds allow.
Old Aug 10, 2008 | 06:58 PM
JimonaWing's Avatar
What do you recommend replacing the lift pump with?
Old Aug 10, 2008 | 07:02 PM
Zeus1987's Avatar
at the very least i would get a airtex replacement pump, they are supposed to be much better than the stock carter lift pump. I have the airtex and it has been doing its job now for about 8 months no problems. FASS, Airdog are the best you can get but $$$, I am looking at a raptor fuel pump
Old Aug 10, 2008 | 07:07 PM
mishkaya's Avatar
Just for a simple check first, you might want to make sure the fuel pump relay is still working. Occasionally they do go bad. On my '01 the horn relay and the fuel pump relay are the same type, you could try swapping them around. You will get the same codes if the relay fails.
mishkaya
Old Aug 10, 2008 | 07:12 PM
Zeus1987's Avatar
hmmm ... could be by looking at the codes it sounds like something electrical said goodbye .... in jimonawing's case i hope it is just a relay
Old Aug 11, 2008 | 05:42 PM
dozer12216's Avatar
Try PD out of Pensacola, FL on ebay. Get lift pump also. They have good deal as have found anywhere.
exwrestler
Feb 5, 2010 09:34 AM
powerrammaster
Jun 28, 2009 10:29 PM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
bward623
Jul 6, 2006 09:15 PM
