Truck wont start...
Truck wont start...
Friday i was out wheeling with a couple buddies in my 96 12 valve - a first -. And i buried it in about 3-4.5ft of water for about an hour before i was pulled out. The truck was idling pretty rough but has since cleared up and ran fine all day saturday and then today at about noon i noticed it was slow starting up.
Then went to a gas station to vaccum out my truck and when i was done i turned the key and it wouldnt turn over, just kept cranking. It continues to just keep cranking until i press lightly on the pedal. then itll start. Anyone know whats wrong? Fuel pump gone bad? Why it happened all of a sudden? And i also should mention the starter was recently replaced. And i crawled underneath the truck and could push the starter up.. All the bolts were lose so i tightened them up and still same problem - just keeps cranking until i give it gas -.
Sorry for the long post, just wanted to get all the information in.
also must mention ive been thru 3 fuel filters in a short amount of time.. they keep either leaking or sumthing else.. usually all dented up. one time one lasted only about 2 weeks. then it was leaking fuel all over the place. bottom and top (everything was tight)
rustydeeretech
Jun 16, 2010 09:41 AM
Stroked-Z
Oct 4, 2008 11:28 AM
