oil smell in cab after oil change
Old 12-20-2006, 08:18 PM
jaroban's Avatar
This only occures after a oil change and goes away after about 500 miles. I have checked the cowl seal and do not notice any problem with it. I removed the crank case bottle and ran a hose downto the lower part of the block. I have read several post on this problem with no real fix.I am using rotella oil. The smell is worse when stoped after a long drive. Hardly noticed when moving. Any thoughts Robby
2001 dodge 250
150,000 miles
Old 12-20-2006, 08:43 PM
TxDiesel007's Avatar
2001 dodge 250
150,000 miles
NOthing out of the ordinary
If u use rotella the smell comes and goes like that, i kinda get used to it, then its gone before u know it. Dont worry about it too much.
Rick
Old 12-20-2006, 09:52 PM
phox_mulder's Avatar
Perfectly normal, and happens with any brand of oil.
Rotella just happens to be the worst offender.
phox
Old 12-21-2006, 08:20 AM
b4wheeler's Avatar
I have the same problem, and honestly don't know if it is the oil that I smell or the fuel that I smell.
I used to smell fuel after fueling up, but that would go away quickly. I now have the oil smell and cannot let the truck idle, as the smell or fumes build up in the cab, and that can't be good.
With the weather getting cold, I like to leave the truck idling when I fuel up or make quick trips into the store. The smell when I return is terrible.
Old 12-21-2006, 08:23 AM
RustyJC's Avatar
It's nicknamed "Rosmella" for a reason!
It's good oil, but that's one reason I've always used Delo 400.
Rusty
Old 12-21-2006, 01:57 PM
D2 Cat's Avatar
Seems to me I saw a bulletin somewhere about the smell of oil right after an oil change. It explained why and what to do about it to help keep the smell out of the cab. Might try a search here.
Old 12-21-2006, 05:48 PM
TIMMY22's Avatar
Its probably the oil that's left on the sleve of your shirt
Try one of those quick drain valves from geno's. wrap a plastic bag around your oil filter after you crack her loose then unscrew it with the bag on to keep the oil from oozing down the chassis.
Old 12-21-2006, 05:56 PM
Hillcountry's Avatar
You can use 3/4inch hose (the clear braided kind) from home centers and relocate the blowby tube to exit behind the engine. I have done this and the smell is gone. Search Blow-by relocation, or puke-bottle relocation and you will find threads about this. There are many who have relocated it and now don't smell it in the cab. It costs about 5 dollars to do, and it saves the smell.
Old 12-21-2006, 05:58 PM
That might be the cowl seal.
Often it half falls off and you'll find it hanging around the air filter/box.
phox
Old 12-21-2006, 06:04 PM
josh brown's Avatar
Dodge makes a oil additive to get rid of the smell call your dealer, if they don't know what you are talking about tell them to look into it, it has a Mopar label on it.
Old 12-21-2006, 06:31 PM
Mike Stowe's Avatar
I was misinformed about the oil capacity of my truck and I filled it with 12 quarts of Delo 400. I had a BAD oil smell. I drained off that extra quart and no more stink.
Old 12-21-2006, 08:52 PM
josh brown's Avatar
11 quarts and a oil filter is how it is supposed to be done right? That makes 12.
Old 12-21-2006, 09:19 PM
Mike Stowe's Avatar
That's what I was told, and it made sense to me, too. Then I found out from other sources (including here) that it was 11 INCLUDING the filter. It shows full on the dipstick, so I'm pretty sure it's right.
Old 12-21-2006, 09:23 PM
Geico266's Avatar
My nose must be burned out. I never smell anything after an oil change. Never have.
Old 12-22-2006, 09:16 AM
b4wheeler's Avatar
phox
Quite possible, as my truck does not have a cowl seal. It was not there when I bought it.
Is this available from Dodge or any other source..??
48
03-30-2009 08:15 PM
2500Ram
11-07-2007 08:42 PM
eightball
04-06-2006 08:30 PM
Trashdawg5050
04-24-2003 10:34 PM
woodpecker
10-04-2002 12:03 PM
Quick Reply: oil smell in cab after oil change
