oil pressure
oil pressure
I want to check what my oil pressure really is, at idle. Can I use a fuel pressure gauge, and screw it into the oil filter housing?
Would that work? If it can measure gasoline, couldnt it measure oil?
If it reads more then 80 psi it will work if it reads less you could over range it. because the oil pressure runs on the high side
GlennRMK
May 24, 2007 10:46 PM
Power Ram 250 C
Feb 20, 2007 11:08 AM
streetsmoker
Feb 22, 2006 06:47 PM
bigragu
Jan 24, 2006 11:16 AM
CIN'S DODGE
16
Dec 5, 2005 04:14 PM
