OD & CC where did they go?
Old Jul 5, 2008 | 04:54 PM
unixcowboy's Avatar
Everything been's too good. No problems, tranny holding up until I can get my 47RH built...
Then the other shoe dropped - big time.
Lost OD and CC yesterday. I've checked the wires and plugs. All seems to be ok.
Speedo and tach still work so I don't think it's the PCM...
Anyone have any ideas ?
Thanks in advance.
PS I'm not against hard wiring a switch for the OD but really miss the CC...
Old Jul 5, 2008 | 05:55 PM
Does it charge?
Old Jul 5, 2008 | 06:02 PM
unixcowboy's Avatar
everything else works...
Old Jul 5, 2008 | 06:45 PM
PCM has nothing to do with the speedo, they share the VSS. A working speedo does not mean that the PCM is getting the message.
I would check continuity between the orange/white wire on the VSS plug and cavity 47 (also has an orange/white wire - go figure) on the PCM plug.
I'm assuming your truck has not been converted to an old style voltage regulator?
Old Jul 5, 2008 | 06:55 PM
unixcowboy's Avatar
That is strange !
I'll check it in the AM. That's one wire and plug I didn't check...
No I haven't converted regulators.
Old Jul 5, 2008 | 07:02 PM
OK, so we know the crank sensor is good.
Old Jul 6, 2008 | 07:17 PM
unixcowboy's Avatar
Or/Wh wire is good.....
What's the wires on the OD? I know one is + and the other is ground...
Which is which - and is the + 5v or 12v ?
Old Jul 7, 2008 | 10:33 AM
Caver Dave's Avatar
If the horn doesn't work, wouldn't this point to the clock spring?
Old Jul 7, 2008 | 12:28 PM
Yes if the horn and cruise dont work then the clock spring is most likely broke.
Old Jul 7, 2008 | 02:06 PM
unixcowboy's Avatar
Unfortunately my horn does work.
That's why this is driving me nuts...OR at least nuttier that normal
Old Jul 7, 2008 | 02:48 PM
Caver Dave's Avatar
The reason I asked... My wifes former '00 Plymouth mimi-van dropped the CC & something else on the steering wheel (radio controls?), but the horn continued to function. Ended up being the clock spring anyway... luckily only $59 "dealer cost" from my 5Star wrencher bud to throw in after work one day.
Wouldn't even let me buy him a cold one for his trouble!
Old Jul 7, 2008 | 03:44 PM
The dark blue wire is 12 volts when the key is on. The PCM supplies ground through the other wire.
So the VSS signal is getting to the PCM...
Will the truck start in Drive?
Old Jul 7, 2008 | 03:59 PM
unixcowboy's Avatar
No
AS I said - everything I could check appears normal.
A/C works, tach works, speedo works...
I'm real close to hardwiring a switch for the OD...IF no other reason than to check and see if the problem is mechanical...
I don't think the CC will kick in unless the OD is on. I don't remember trying to engage CC with the OD locked off...
Old Jul 7, 2008 | 04:14 PM
Start the truck, unplug the NSS, and go for a ride. See if you get OD and cruise back.
Check for a ground at cavity 30 on the PCM connector with the shifter in Drive.
Old Jul 7, 2008 | 04:16 PM
unixcowboy's Avatar
NSS What's that? Did you mean VSS?
