nv5600 wont go into reverse
Old Oct 19, 2005 | 12:00 PM
getblown5.9's Avatar
the only way to put the truck in reverse after being parked is to put it in 2nd gear and pop the clutch jsut a little to make the truck move just an inch or so then it will go right into reverse real easy. is it because of the short throw kit? or do you think replacing the fluid will help
Old Oct 19, 2005 | 08:48 PM
blackdiesel's Avatar
Registered
i cant really see what replacing the fluid would do.... but i just blew mine up so what would i know
Old Oct 20, 2005 | 06:25 AM
VADSLRAM's Avatar
You can select between the forward gears, just not reverse?
two possibillities, linkage or syncro
IMHO you must have shredded a syncro since linkages would effect more then just one gear. Not a terminal problem and can be ignored for a while if you don't mind the hassle. Drain the oil and see if there are any brass particles in it. If that's the case then your going to need to rebuild the tranny or live with it.
Old Oct 20, 2005 | 07:41 AM
the BD short throw has been installed since i bought the truck used. i replced the clutch and master/slave cylinder back in july with a LUK clutch and ever since i replaced the clutch is when ive been noticing the problem going into reverse. im gonna change the fluid to Royal Purple Synchromax this weekend and i guess ill be looking for the shredded synchro. every now and then i have a little difficulty going into second when starting off from a stop, but its not all the time. also i notice that when in any gear there is ALOT of play in the shifter. i can wiggle the shifter about a 1/2" to 3/4" in any directions while its in a gear. this may be the linkage as you say. i guess ill deal with it for now until i can afford a tranny rebuild.
Old Oct 20, 2005 | 08:00 AM
Registered
i just replaced my clutch a month or so ago and the shifter bolts that hold the shifter onto the trans worked themself loose. you might check those 4 bolts. that might be your problem.
Old Oct 20, 2005 | 08:42 AM
nope checked them two weeks ago when my BD short throw shifter snapped off at the threads and i had to weld it back on. it wont break again for sure. this problem was there before the shifter snapped too...and its still there
Old Oct 20, 2005 | 09:16 AM
PourinDiesel's Avatar
Throw the truck into 3rd without releasing the clutch then over to R.
reb0957
Jan 17, 2007 10:07 AM
BigDan
Jul 8, 2006 11:04 PM
05mxdiesel
17
Aug 15, 2005 06:01 PM
Jdonoghue
Jul 6, 2005 10:07 AM
stonewalldiesel
Aug 26, 2004 11:16 AM
