no start after fuel filter change
Old 11-14-2008, 05:21 PM
akrr154's Avatar
2000 ctd won't start after fuel filter change. Not the first time I've changed the filter and I did the starter bump thing to fill the housing. There is fuel in there. I disconnected the fuel line at the front injector and had my wife turn the engine over while I watched. No fuel came out the fuel line.
I don't get any trouble codes from either the odometer or with a code reader. I disconnected the battery in hope that the computer(s) might "relearn" something.
I have a cheapo vacuum/fuel pump tester but not sure where to connect it or if lift pump pressure can even be checked when truck isn't running. There is a valve similar to a tire valve stem on the filter housing only it's bigger. Looks like the right place to get a pressure reading but not sure where to get a fitting like that for my guage.
When the truck had 95k on it the dealer replaced the lift pump and I lost the vp44 at 115k. I know I should have replaced the lift pump with something better but right now I just want to get it running again. Thanks for any help.
Old 11-14-2008, 05:45 PM
2500Ram's Avatar
Sounds like a dead LP to me. Open up the filter again and bump the starter. Does the bowl fill up and overflow? If not, new lp asap. As for your question on the shrader valve on top of the filter cap that is a good place or there is another shrader valve (test port) on the VP itself. Genosgarage.com has a hose kit you can buy for about ~20. Haven't checked recently so price might have changed.
Not that I would recommend you do this but... I've read you can pressurize the fuel tank to prime the VP and get the truck started. Once running the VP will provide it's own fuel flow but is very bad on the pump.
Good luck
Old 11-15-2008, 03:24 AM
dozer12216's Avatar
My favorite trick is jumper a hot wire into the LP connector on white lead. The pump will run continouslly. I do this after filter change and before cranking engine or bump starting. Never misses a lick. JMHO The black wire is ground, so don't make a mistake.
Old 11-15-2008, 06:45 AM
smokinram99's Avatar
try to remove air from the system..unscrew a little the fuel supply banjo bolt onto the VP and bump the starter, so the LP run and you'll check if fuel leak from that banjo bolt.. you hear the buzzz from the LP when you bump the starter?'
rob
Old 11-16-2008, 07:54 PM
psd tuner's Avatar
agreed bump the starter, let the pump run. open the ff drain, pull the key out, bump the starter and watch the fuel comming out. it needs to be a steady stream. make sure your lp is working.
440FURY
06-11-2006 08:12 PM
steverctx
21
11-18-2005 07:45 PM
Ian
10-05-2005 05:40 PM
jlells01
09-01-2004 08:42 PM
sjester
08-01-2004 07:50 PM
Quick Reply: no start after fuel filter change
