No 4 Wheel Low - At All
I recently perchased a 94 Cummins with the auto trans. I can not for hte life of me get it to shift into 4 Wheel Low. I can get it into neutral no problem, but then it all stops, i can feel it rub teeth, but it wont shift. ITs not that important, but something id like fixed.
Any ideas?
Mike
Any ideas?
Mike
hi
have you tried it with the engine off ?
or while running ?
if you go to nutral in the transfur case you cant get back in gear with it running i believe , dont use mine too often.
so you should be able to go from 2 h to 4 h on the fly but stop for 4 low 1 thin ?
or while running ?
i've tried off/on - stopped/slighty roling everything
You're not supposed to stop in neutral with the shift lever. That'll just grind teeth in the transfer case. After 4H, move the lever to the right a little, then go straight down to 4L without stopping in neutral. You have to be stopped or going less than 3 mph when switching to 4L.
rjm022
13
06-09-2023 06:34 PM
