What next?
Old 04-13-2006, 02:05 PM
ChuckW's Avatar
Question What next?
I've been talking to a couple of other guys about what I should do next to my truck. I've already got an edge comp and 80 hp injectors. What next? I've heard turbo, fuel system, and a few other suggestions. What should I put on next?
Old 04-13-2006, 10:03 PM
Ph4tty's Avatar
Guages, lift pump, and fuel lines/banjo bolts. If you're running the truck hot with comp and sticks then pyro and fp guages are needed. And if you're putting more fuel out then you need to make sure you're putting more fuel in =P
Old 04-14-2006, 10:34 AM
duallydave's Avatar
Talking
gauges and a smarty.the smarty stacks nicely with a comp and injectors,put her on #8 with your comp on 5/5 and yehaaaaa,and you already got the clutch for it,oh ya you may need a better fuel system,fass or holley inline with your lp,the smarty rocks with a comp,
Old 04-14-2006, 10:58 AM
smokindog's Avatar
Ummm,
Can we say 4" exhaust!? And gauges are a priority with the Comp!!!
CurtisvilleCummins
03-10-2003 02:24 PM
02-20-2003 08:17 PM
Fillerupsonny
11-21-2002 08:51 PM
Dusty 96
10-13-2002 06:54 AM
Quick Reply: What next?
