New XZT stacking question.
I am wondering if there is a way to hook the new XZT tow box up & still have my Drag Comp plugged in. I am not trying to run them both together as a stack, but just hook them up & be able to turn the XZT on for towing & Comp on for play. Is this possible? I would gladly pay for a custom harness that would let me shut off each one individually or something if needed.
It will work but you are going to have to modify the wiring harness of one of them to make it work.
You can use t-taps or whatever you want but, you are going to have to connect the data link wires together. Then stack the map sensors on top of each other. I would normally say put ours in the MAP first but, I have never done it with a Comp so I am not sure what to tell you is best.
Other than that as long as you make darn sure you turn one off while the other is on you will be perfectly fine.
On the Can Bus you are fine with tapping the wires to each other, I know that for a fact.
06CTDforAU
01-27-2008 11:25 PM
bluebull
08-16-2007 04:51 PM
JBlackwell
07-31-2007 01:49 PM
RedRacer44
32
07-01-2007 01:14 PM
