New Tie ROd Ends
Old Apr 19, 2011 | 08:18 PM
donsharp1959's Avatar
New Tie ROd Ends
Just replaced both TRE's to combat wobble. Its worse. Going to take it to an alignment shop tomorrow and have that checked after replacing the TREs. THats the first time I've done that. Could it be alignment? Or did I put it back together wrong. COunted the threads showing and all and seems to steer fine but steering wheel is not centered (don't remember if it was before) and of course the wobble is there.
Old Apr 19, 2011 | 08:37 PM
sooty's Avatar
alignment shop might find other problems, if not, you might consider a steering shock/stabilizer
Old Apr 19, 2011 | 09:24 PM
DPFservice's Avatar
How are your kingpins? Now that your TRE's are solid they are not taking the slop from other worn parts.
Old Apr 21, 2011 | 10:36 AM
AUGIE DOG's Avatar
The 1st gen doesn't have king pins.
Old Apr 21, 2011 | 11:20 AM
Paul S.'s Avatar
A 4wd (W) does.
Old Apr 21, 2011 | 11:58 AM
Subliminal's Avatar
Yeah, you've got a problem somewhere else.
You best (first) bet is to get a wife/girlfriend/friend/child to get in the truck and move the steering wheel side to side while you lay under the front of the truck and look at all the linkages...see if you can hear any popping or see any slop anywhere. These front ends aren't really all that complicated, so it shouldn't be impossible to find the issue.
dogcamo
Feb 28, 2010 10:21 AM
ddestruel
Dec 7, 2008 06:37 AM
99 cummins
Mar 8, 2005 08:56 PM
doug
May 24, 2003 08:55 AM
powerwagon440
May 1, 2003 05:20 PM
