i need some oppions
Old Dec 12, 2009 | 10:51 AM
kennyblatz's Avatar
i need some oppions
my buddy has a 01 dodge dakota, the motor crapped out so we got a good motor for a swap. same motor 3.9 v6. when swapping is it easyier to pull the motor and tranny and swap tranny to the other motor outside the truck or just undo the bell housing under the truck and leave the tranny in?
second question, as i know nothing about autos after taking the bell housing off will the tourqe converter be bolted to the flywheel as a clutch would?
thanks
Old Dec 12, 2009 | 12:00 PM
Mike Holmen's Avatar
The Guru
Unbolt the converter, leave it in the transmission. Chances are if you don't remove the bolts you'll damage the front seal on the automatic transmission. Once the engine is out you can remove the torque converter?
Is the truck a 4wd truck or 2wd? I'm looking for a cheap smallish 2wd truck.
Old Dec 12, 2009 | 12:07 PM
kennyblatz's Avatar
2wd ext cab, body is real nice. he wants it gone he's broke. if you want i can shoot you a pic
Old Dec 12, 2009 | 12:19 PM
The Guru
Take a pic and PM you if I want come-up and take a peek-see
bsj04
Sep 20, 2007 08:09 AM
Mini_Donkeys
Apr 19, 2007 12:21 PM
TxDiesel007
Nov 29, 2006 12:08 PM
SilverHoss99
Oct 31, 2005 07:22 PM
JKM
Mar 4, 2005 03:33 PM
