need some info on turbo
can some explain how the turbo gives the engine more power, I do not have a guage on my turbo but got the pressure checked yesterday and have about 18psi thru all 6 gears. we put a new pressure sensor in today but it hasn't helped. Under a 10,000# load I'm very underpowered. My lift pump is brand new and vp is new. How can I tell if the turbo is going out and how hard is it to do a rebuild? any help would be great,Thanks
The turbo uses exhuast gas pressure to power a turbine wheel that is attached to a similar wheel on the intake to pressurized the air in the cylinder above atmospheric pressure. With more air in the cylinder you can add more fuel and have it burn more cleanly producing more power.
Turbos can leak and make noise when going out. 18 psi is about right for stock. Have you checked your fuel filter? Not enough fuel can equal not enough power and a ruined VP44.
But in a diesel engine, if you want more power you have to add more fuel!
RJ
can the waste gate be stuck open, the fuel filter is new, my lift pump which is stock was replaced 2 months ago and was just replaced again 2 days ago because it was reading 0 pressure, i havent gotten a fuel gauge yet cause i thought i would have some time. could my vp be dead already. i can get it replaced under warrenty.cause i replaced it when i put on the newl ift pump.
Check fuel pressure at VP44 banjo fitting. Must be above 5 psi.
Check for fault codes. Three key on cycles and read odometer.
Are you somewhere cold and been feed some kerosene?
10000 extra is pretty good load especially on hills. JMHO of course
If you're building 18psi of boost, your wastegate isn't stuck open: I'd look for fuel issues. 10 000 lbs is a hefty trailer though: you may just need to look at some basic performance upgrades.
Randy.
Randy.
TNRIPNROR
Apr 17, 2009 01:10 AM
Bswope
51
Feb 9, 2009 11:16 PM
sledneck1
Jun 28, 2007 04:05 PM
Mini_Donkeys
Apr 19, 2007 12:21 PM
