I need some direction on air horns??
Old 05-27-2009, 01:07 AM
bucknasty's Avatar
I picked up a set of chrome Wolo Air Horns. All I have is the horns. These have a 1/4 fitting for the air fitting that are extremely loud just by blowing through them. What else do I need to run these? Small compressor or air tank? Obviously, I know nothing about air horns! Just looking for some direction here! Thanks in advance
Old 05-31-2009, 06:24 PM
DarkDesertCTD's Avatar
I have train horns that were on my 06. Havent installed them yet on my 08. I got the complete kit at www.mypushcart.com. Good service. I wanted onboard air as well so I mounted the compressor and tank in a bed box so I can run my air hose out of it. I've got a Viair 450C compressor and a Viair 5 gallon tank. There are guys running 3 gallon tanks and mounting them and the compressor on their frame rails under the truck
Old 06-01-2009, 02:25 AM
Dodgefan01's Avatar
Check out HORNBLASTERS! They HOOKED me up with everything and have GREAT customer support..
Old 06-01-2009, 09:29 AM
klx650a2's Avatar
I'm going to be running an Air Zenith pump. 200 psi, 100% duty cycle and 2.9 cfm. More money, but it can be mounted in the elements.
Old 06-14-2009, 03:34 AM
Dodgefan01's Avatar
I got my compressor/tank in my toolbox. The only items in the "weather" is my horns
Old 06-14-2009, 09:41 AM
mikmaze's Avatar
another vote for compressor inthe tool box, thatw where both of mine are, but the 8.5 gallon tank is under the truck. only other thing to add is for gods ssake, use a air valve for the horns, not a solenoid, much better flow, control, and variable output..........
Old 06-14-2009, 04:42 PM
alMout's Avatar
You need to determine the max pressure the horns can handle. Run too much and you will blow out something.
Old 06-15-2009, 12:44 AM
Found a couple of the compressor and Tank mounted in my bed box. As someone else said above, only thing in the elements are the horns.
Attached Thumbnails I need some direction on air horns??-395080.jpg   I need some direction on air horns??-395081.jpg
Old 06-15-2009, 05:06 AM
Dodgefan01's Avatar
****, i wish i had pics of mine. I mounted compressor/tank to board for easy access if need be
Old 06-15-2009, 11:58 AM
01RAMer's Avatar
I'm personally am using the Viair Compressor and tank. Might check out "Airhorns of Texas".
Asher
11-07-2007 03:06 PM
Asher
10-27-2007 09:50 AM
carcrz
09-17-2006 02:22 PM
howe719
04-05-2006 07:43 AM
Palmetto_kid
02-24-2004 05:13 PM
Quick Reply: I need some direction on air horns??
