Need replacement for 05 Ford
Old Apr 29, 2007 | 09:38 AM
Hedgehog's Avatar
I have a fully loaded 2005 F350 dually diesel that I plan on replacing. It only has 13,000 miles but its time to go. I tow a 12,000# fifthwheel camper approx. 1,000-2,000 miles a year. It has a pin weight of approx. 2,400#'s. Can I safely tow this with a 2007 2500 quadcab SWB 4X4? I am tired of the dual wheels that's why the mileage is so low on my Ford and a local dealer has a few 5.9's on the lot. Ultimately, I would get a 3500SRW but that's not an option if I want a leftover 5.9 motor. Also, does the 5.9 have a EGR system? What is the unloaded vehicle weight of a 2500 quadcab, shortbed, 4X4? Any input would be appreciated.
Old Apr 30, 2007 | 10:03 AM
KBennett's Avatar
Here is a link to the Dodge website to calculate the towing capabilities:
http://www-5.dodge.com/vehsuite/TowingGuide.jsp
This is what it spit out:
With 3.73 Axle Ratio You Can Tow 13000 lbs
Gross Vehicle Weight Rating(GVWR)[i]=9000
Payload[i]=2168
Curb Weight[i]=6832
Curb WeightFront/Rear=4194/2638
GAWR[i]Front/Rear=5200/6000
Gross Combination Weight Rating(GCWR)[i]=20000
While it's not listed in the charts, tongue weight [i] is also an important consideration
Old Apr 30, 2007 | 10:21 AM
Fiftygrit's Avatar
My 06 2x4 quad cab auto, 373 gears will pull 13,400 pounds, so i think the 4x4 will pull a little more, carrying cop, is around 2800 pounds, I pull a 8000 pound TT no problem, good luck
Old Apr 30, 2007 | 01:46 PM
beretzs's Avatar
I know the weight guys will freak out over this, but with a set of Airbags in the rear of your 2500 you have all the same suspension as a 3500 SRW guy. Also, with a good slider, I would think you would be fine for pulling your trailer. Yeah, you give up a little without having duals, but if they are too much of a pain, why bother, if you are over on your tires, you can always go to a higher rated tire. No, the 5.9 Cummins does not have an EGR system. If that is what you want and they have a truck for you, get it and run with it. Guys are pulling trailers like yours all the time. If you feel safe and drive safe, go for it. Scotty
Pele
Cummins Conversions
May 21, 2014 06:49 AM
SOhappy
Jan 4, 2013 02:33 PM
horselady
Jan 27, 2009 12:01 AM
toupee
Aug 10, 2007 01:44 AM
Stamey
Apr 4, 2004 09:32 PM
