Need Pic of Throttle Cable/TV Cable
Old Oct 30, 2007 | 06:01 PM
90firstgen's Avatar
I need a pic of where all the linkage ties together by the intake. My friend's 92 with A518 is missing something that keeps all those cables tight. when the pedal is moved, nothing but the throttle moves until (very hard to put into words here) the adjustable linkage parts bottom out. I think this is causing his down/upshift problem. Anyway, a few pics of how everyone has their cables adjusted and what keeps them tight etc... Thanks a million
Dan
Old Oct 31, 2007 | 04:28 PM
90firstgen's Avatar
Bump
Pleeeeeeez!
Old Oct 31, 2007 | 04:54 PM
BC847's Avatar
1st Generation Admin
My mess . . . .
(Anybody got any WD40? )
Hope this helps.
Old Oct 31, 2007 | 07:33 PM
90firstgen's Avatar
OK, the eyelet things (red arrows) are not supposed to slide on the pin (blue arrow) correct? Because I still don't see whats keeping them secured to not let the pin just move around inside of them.
Thank you so much for the pics BC
Old Oct 31, 2007 | 07:38 PM
They do slide, and they are supposed to. The one closest to the engine is for the cruise, the one with the spring hooked to it is for the trans.
Old Oct 31, 2007 | 07:41 PM
90firstgen's Avatar
I feel really dumb now..... Thanks for the help fellas! I guess I was trying to fix something that wasn't broken. Why do they have so much slack in them?
Old Oct 31, 2007 | 07:46 PM
BC847's Avatar
They are intended to slide back and forth inside the slots of each cable.
Such allows the mechanism to be "Set into place immediately, and delayed to return".
The TV cable for example, It's such that when initially moving the throttle open, the TV is moved along with it thus increasing transmission line pressure, etc to accommodate the additional power without slipping, yet not so high so as to have clutches engage with Banging force. Mash the pedal further has the same immediate results.
When releasing the throttle such as coming to a stop, the throttle linkage moves the opposite direction, having that pin now move freely in the slot of the TV cable. As such, the increased transmission line pressures, etc are delayed in lowering so as to eliminate clutch-pack slip,etc, due to the still high winding engine's momentum. . . . sorta.
Make sense?
Old Oct 31, 2007 | 07:55 PM
90firstgen's Avatar
Makes perfect sense! Thank you again for posting
Old Apr 13, 2008 | 05:48 AM
archer39's Avatar
i know this is an old thread but i can't see making a new one with such great pictures in this one. the cruise control cable, are there any adjustments that can be made to it? mine is very loose and binds the throttle when coming down to idle.
Hercules
20
Nov 9, 2009 10:15 PM
DMS1707
23
Nov 5, 2008 12:53 PM
Kirk T
Sep 20, 2006 07:19 AM
hellotbone
Oct 7, 2003 06:54 AM
Iron Horse
Nov 24, 2002 10:32 PM
