NAV system with Satellite on '06 ?
Old 05-12-2009, 08:22 PM
Valv's Avatar
Does the '06 version of the NAV system has SAT radio capability ? I don't see the "tab" on my screen.
Is it something I can add with newer software, plus adding a satellite antenna, etc ?
Old 05-14-2009, 06:13 AM
Valv's Avatar
Nobody has an answer ?
Old 05-14-2009, 07:38 AM
Pooter's Avatar
You have a mode button correct?
It should be able to toggle between am/fm, cd and sirius if you install a factory sirius unit...
Check out the install guide on mopars website.
Old 05-14-2009, 08:07 AM
Jeff in TD's Avatar
Mine has Sirius. I thought they all came that way, but maybe not.
Does yours have the antenna, a little puck ahead of the center brake light?
Old 05-14-2009, 10:11 AM
PRO-NRA's Avatar
If yours is the REC model like mine it has sat radio. Also mine came with U-connect.
Old 05-14-2009, 11:50 AM
Dodgezilla's Avatar
It may not show the tab unless you have the satellite reciever hooked up to the back of it. The one in my "Old" 08 truck even had a tab for the VES
Old 05-15-2009, 10:06 PM
Valv's Avatar
I have the VES but no tab for Sat and no antenna on roof.
Where can I find out about the installation besides talking it to a dealer ? Also can I get XM or do I have to have Sirius ?
Old 05-15-2009, 10:23 PM
Jeff in TD's Avatar
My best guess would be you would need the sat equip from the dealer? I assume the head unit would recognize it?
It appears to be a sirius receiver, but the two have merged (you can get Sirius plus the best of XM).
WmKRider
12-27-2007 06:25 AM
PASSMORE
09-07-2006 09:49 AM
Mostwanted
03-02-2004 07:32 AM
maybe2004
10-20-2003 03:39 PM
Quick Reply: NAV system with Satellite on '06 ?
