My 12V won't start
Old 10-01-2011, 12:16 PM
taneum's Avatar
My 12V won't start
I went to start my truck this morning and couldn't get her to start. It cranks over and tries to start. I'm getting smoke out the exhaust. It fired for a couple seconds and that was it and it didn't sound happy. It's all stock and I have never had a starting issue. I parked it on a hill and I'm at 1/8 tank. Could I have sucked air in the tank? Could it be the starter shut off solenoid if I'm getting smoke (and it kind of wants to start)?
I just turned it over after wait for an hour and now it doesnt want to try to fire at all.
Any help would be greatly appreciated.
Old 10-01-2011, 02:07 PM
Hodge's Avatar
My guess would be that you are not getting diesel because of being so low on fuel and parked on an incline. How about getting a couple of 5 gallon cans of diesel and putting in it, and see what that does?
Old 10-01-2011, 02:48 PM
PWong's Avatar
I agree with that idea.
Old 10-01-2011, 03:02 PM
taneum's Avatar
If so, I just cant add diesel and fire her up? I will have to pull injector lines and reprime the fuel the system...... Correct?
Old 10-01-2011, 05:15 PM
Hammily's Avatar
You could most likely could get away with adding the fuel and manually pumping the fuel pump until you get fuel to the IP. I have had air in my system often and this has always worked for me.
Old 10-01-2011, 09:11 PM
taneum's Avatar
Thanks for all the advise. I ended up filling the tank and pumping the primer bulb till my hand fell off then used my 1 remaining hand to finish. She started right up. I guess I wont be parking on a hill with a low tank any longer.
ado2b1
12-16-2008 03:19 PM
Machinos
03-16-2008 01:34 AM
falcone
09-23-2005 03:40 PM
Quick Reply: My 12V won't start
