how much will timing lower temps?
Old Dec 11, 2002 | 04:27 PM
Dusty 96's Avatar
I was wondering how much bumping my timing (assuming mine is still at stock) up to around 16 degrees or so will (if any) help lower my egt's???? thanks for any replies, also how hard is this procedure, I know there are some special tools required, anybody know about how much $ for the tools???? thanks again, Dusty
Old Dec 11, 2002 | 05:24 PM
Rebel's Avatar
Re:how much will timing lower temps?
Temps went down about 50* F on my truck. It also cleared up a whitish haze at idle when cold due to the 370's I put in. I'm timed at 16* ;D
To set my timing I used a dial indicator with a magnetic base that I already had and borrowed a delivery valve socket from a friend. You will also need a barring tool. I think you can get the Cummins engine timing kit from Snap-On for $230ish.
Old Dec 11, 2002 | 06:04 PM
Dusty 96's Avatar
thanks rebel,<br> I have a friend/mechanic who I think has the stuff I need, I'm pretty sure I could borrow it, maybe even con him into helping w/the timing, thanks again, Dusty
smog2001
Aug 10, 2007 09:32 AM
Hunter11
Jun 15, 2006 01:25 PM
67HotRod
Jul 1, 2005 01:04 PM
SAVOY1964
Mar 30, 2005 08:22 PM
