MP-8 Install questions again.
Old 12-23-2008, 03:40 PM
RonP's Avatar
Smile MP-8 Install questions again.
I have done some searching and it appears that folks say it goes either way when hooking up the MP-8 when you ahve a RP gauge already installed. I hooked it up like this, Gauge to rail, MP-8 into gauge, factory into MP-8 and the pressure gets up ther and appears to be working well.
I did notice that every now and then the RP drops for a sec and then starts climbing.
Then I called TS just to see and they said the MP-8 must be plugged in first. So I went MP-8 to rail, then gauge, then factory sensor and the truck ran the same but the RP gauge didn't go nearly as high. So I moved them back to the original setup.
so how is everyone hooking theirs up?
Thanks again Folks
Old 12-23-2008, 03:51 PM
Spooler's Avatar
Hook it up the way you originally did to get accurate rail pressure readings. If you go after the MP-8 then you will be getting the fooled RP readings that the MP-8 wants the ECM to see.
Old 12-23-2008, 03:53 PM
rock crawler's Avatar
I have the Isspro Performax gauges and I was told by Isspro to plug in the gauge first, closest to the sensor. I had called TS before that and they told me it would not work and that I cannot add anything else in with the MP-8. I have been doing all my mods, so I have not had a chance to try it out yet.
Old 12-23-2008, 04:09 PM
Cummins610's Avatar
Gauge then MP8
Old 12-23-2008, 04:54 PM
SlowSixSpeed's Avatar
TS is wrong we're right.
gauge first
Old 12-23-2008, 06:01 PM
RonP's Avatar
Ok, thats how I have it now. thanks guys. Now just how noticeable should it be? I know that is probably more in the eyes of the person running it, but I can tell it is there, just not as pronounced as I thought. I am running it with Revo SW7 tq3,timing0, rp1 now. I thought it would show up more than it seems down low right at the point the truck starts moving like from a redlight.
Old 12-23-2008, 09:14 PM
If you still have the stock 04 turbo you wont see much if any of a difference.
Old 12-23-2008, 09:16 PM
RonP's Avatar
I do and that is next on the list. Thanks for the reply.
Steven K
06-04-2009 10:32 AM
b84u
02-20-2006 01:04 PM
chuck3
02-01-2005 07:47 AM
gunracer1
18
11-24-2003 08:56 AM
Sean S
11-15-2002 12:25 PM
Quick Reply: MP-8 Install questions again.
