Modded p7100s
Old 05-29-2005, 11:44 PM
Jambbii's Avatar
Modded p7100s
I am eventually going to need more fuel and I was just wondering how much a modded p pump cost or to have one worked.
Old 05-30-2005, 09:44 AM
bmoeller's Avatar
Are you sitting down?
Could be upwards of $3k +. Depends on what you want done to it, and who does the work.
Old 05-30-2005, 11:57 AM
Jambbii's Avatar
That is pretty pricey. What is the going rate for a 215 pump these days?
Old 05-30-2005, 04:02 PM
acdc's Avatar
It wont cost anywhere near that if you go call Interior Diesel Performance ask for Rob 1 250 833 9904 he did mine and it is amazing the amount of fuel he can get out of a pump and have it burn clean
Thanks Ted
Old 05-31-2005, 12:31 PM
1BadRam's Avatar
If J.R. Adkins a call if you need some pump work. 3K sounds a bit high, unless your putting everything into it, 13mm plungers and barrels, quick rate cam and etc. You can get alot of fuel from a 215 pump. I bought my 215 pump for $700 with throttle linkage and everything else on it. J.R.'s number is 317-281-3130
Old 05-31-2005, 03:00 PM
MCummings's Avatar
The P-7100 pumps are great pumps.
Depends on what you want to do, the sky is the limit. It's easy to go over $4k on a P-pump setup. But, it's also not hard to keep the bill under $1,000.
If you want stupid power, then you need a stupid pump, and that comes with all the extra driveability side effects.
I had one of JR's 1450 pumps, and it was just crazy, with my '55 and Big Air, I could hit 100PSI boost no problem, and rev over 5,000.
Drop a PM to J.R. or I and we could hook you up tight.
Merrick
Old 06-01-2005, 12:03 AM
halerazor's Avatar
sheid, piers and columbus diesel supply are the best when it comes to these pumps
Old 06-01-2005, 12:36 AM
dodgeman01's Avatar
I'm not knocking them but to say thos are the best is not quite right. Schied is great but you can get the same stuff cheaper. I have seen a few pupms from J.Rs pump guy and they are just as wicked as any of them out there. Mine soo will make the trip to his shop when I get a new turbo to burn the extra fuel.
DM01
Old 06-01-2005, 11:26 AM
halerazor's Avatar
i don't know of any other shop that makes billet pumps for pulling besides CDS check this link pretty sweet
http://www.columbusdieselsupply.com/tpindex.htm
Old 06-03-2005, 02:42 AM
Jambbii's Avatar
Thanks for the info guys, I am not going stupid power. I just want to be able to push my combo to the limit (when I get twins) I know my 160 pump will not satisfy my need for speed either
Old 06-03-2005, 09:41 AM
MCummings's Avatar
IMHO, I would remove your pump, get it rebuilt, and balanced, stay with the stock P&B's, chenge the GS's to something around 4k, put 191 DV's (the lsr cut ones are a bit smokey), and have the pump turned up to about 80%, or so. This will still cost over a grand, but the power increase has no comparison.
Merrick
P.S. Don't forget about getting some larger injectors, EDM'd
kruegerlouie
09-07-2007 07:09 AM
Crimedog
08-21-2005 11:10 PM
mr T
11-22-2004 07:58 AM
DavidTD
16
06-13-2004 08:24 PM
ridofpwrstroke
02-24-2003 01:44 PM
Quick Reply: Modded p7100s
