Massive oil leak
Old Jan 30, 2008 | 01:02 PM
genesis's Avatar
Massive oil leak
2001 CTD, 4X4, A/T
I have a massive oil leak in the aluminum case that holds the gear drive behind the stamped timing cover.
Right behind the water pump is is gushing oil.
After i did the CCV hose out the back of the truck, one of the guys that works for me decided to kink the hose and crankcase pressure blew out the gasket.
Is there anywhere online that has the repair manual online that I can look at or do I need to go buy the book?
I have the radiator out and the fan off and I can see that the balance, water pump, and timing cover have to come off.
What kind of surprise am I in for when I get inside the timing cover?
Do I have to remove the oil pan?
Anything else I should do besides new belt and hoses while I'm in there?
Any help would be appreciated.
Thanks!
Old Jan 30, 2008 | 01:55 PM
John Faughn's Avatar
You may be the victim of a KDP = killer dowel pin , lots of info here , do a search on KDP .
Its a pin that aligns the block & timing cover [ alum ] , it has a history of falling out , there are fix's for keeping it from doing that [ which you want to do after fixing ] .
But if your lucky , I've seen the bolts loosen timing housing & blow out a gasket .
You need to power wash to confirm , gasket / case .
Old Jan 30, 2008 | 02:02 PM
SIXSLUG's Avatar
A 2001 should have the retainer on the KDP. Kurt
Old Jan 30, 2008 | 06:42 PM
Tocapet's Avatar
Right, no KDP on 2001s. That was a 12-valve problem
Old Jan 30, 2008 | 07:27 PM
Fishin2Deep4U's Avatar
KDP is an issue even on the '02s.
Look for a crack or hole under the water pump in the aluminum case.
My dad's '02 had an old style case and did have a failure.
CHECK ALL TRUCKS THROUGH '02!!!
Dave
Old Jan 30, 2008 | 10:19 PM
mini14's Avatar
i dont think u have a crack, your friend kinking the line built up too much back pressure in the motor and it blew the gasket to escape......http://www.trademotion.com/partlocat...30&catalogid=1
Old Jan 31, 2008 | 01:24 PM
SIXSLUG's Avatar
Why did your friend kink the line?!? If its just a blown gasket you're way ahead of the other problems it might be. KM
Old Jan 31, 2008 | 03:20 PM
genesis's Avatar
It was definitely a kinked breather line.
If I hold my finger over it oil gushes out of the timing case next to the water pump and when i let it go nothing comes out.
I was just wondering how tough it was to take all the stuff off insidee the timing case to change the gasket.
I guess i will have to go but a manual.
Old Jan 31, 2008 | 03:21 PM
genesis's Avatar
I didn't see the link in your post until just now.
Thanks!
Old Feb 3, 2008 | 12:16 PM
genesis's Avatar
Anyone know the best buy on a manual or disk?
Do I have to pull the cam when I get in there or does the cam gear unbolt from the front of the cam?
Is that the worst part about this project?
Old Feb 3, 2008 | 12:32 PM
torquefan's Avatar
Yes, you have to pull the cam, and I think it's the worst part. The valvetrain will have to be removed, and you will have to fabricate a dozen wooden dowels to hold the lifters up away from the cam. You'll have to remove all the coolers in front of the engine, as well as the front bumper. It's a long job, but you'll know your truck a lot better by the time it's over.
Old Feb 3, 2008 | 01:41 PM
The 2001 has a press on gear.
I have seen it removed with carefull heat, but I would also recommend pulling it.
The gear should be pressed off and back on. Although I have heated gears in the oven and dropped them onto the cam with no major issues.
This may be a good time to add a cam.
Dave
Old Feb 3, 2008 | 08:55 PM
Junk Man's Avatar
I found an 01 manual on the web. Snagged it but have no way of hosting i & it's too big for email. Search the forums. It's out there.
DZLPWR
Apr 14, 2009 09:41 PM
fireman0977
15
Oct 13, 2008 09:43 PM
rdavisDGM
Feb 4, 2008 11:35 PM
MAKIN'SMOKE
Jan 27, 2008 07:42 PM
Bad Ramer Jamer
Mar 12, 2007 01:39 PM
