mach injectors
Old 04-05-2006, 08:14 AM
Registered
blackdiesel's Avatar
mach injectors
ok if i was to set up my truck with mach 6's and a smarty i would be around the 475 hp mark. but if i put the mach 7's in and a smarty i would be around the 495 mark right? is there that big of a difference in the two injectors? is the mach 6 the better injector? they say 7's are for twins only but the 6's are ok to run with a big single? i plan on running a phat shaft 64 with this. Opinioins? would this be pushing the stock HO vp44? when this one goes out i plan on stickin a hrvp44 in. Thanks
Old 04-05-2006, 08:18 AM
Mike D's Avatar
From my understanding Mach 4.5 will drain the HO Vp44 plungers.
Old 04-05-2006, 08:40 AM
HOHN's Avatar
With an untapped wire, you could probably run an M6.
I think the M4.5 limit for HOs is spec'd by Don with the assumption of a wire-tap fueling box, but I could be mistaken.. If I am, then follow Mike D's advice and stick with M4.5 or smaller.
Maybe Don will chime in..
Old 04-05-2006, 03:04 PM
Mike D's Avatar
You might be right Justin. I was thinking wire tap after reading his sig. Mid 5's or 6 would probably drain 'em pretty dry without a tap.
Old 04-05-2006, 03:38 PM
Registered
i dont think ill put a box on it. (right now anways, maybe when i get a hrvp44)
but mach 6's and a smarty would give me around 475 right?
Old 04-05-2006, 05:53 PM
Bob Wagner's Avatar
Dieselnutz got 440HP with his 02 HO and Mach 4's and Smarty. I got 401HP with Caatcher and Mach 4's on my ETC auto.
If you have enough air like a phat shaft 64 or 66
There should be some more numbers coming out soon.
Old 04-05-2006, 07:07 PM
inline6power's Avatar
smarty
have heard a number of people mention the smarty on here. i am totally new to this or completly oblivious. what is it and what does it do.
Old 04-05-2006, 07:13 PM
AAmeeting's Avatar
Its the best thing since the Cummins was first put in the Dodge, www.madselectronics.com Its pricey ->650.00
Old 04-05-2006, 07:55 PM
Jetpilot's Avatar
Mach 6's, Steroid B-1, and a timing box yeilds around 480-490 RWHP. I would bet the Smarty would have the similiar results.
Doug Smith
Old 04-06-2006, 10:41 AM
Registered
Doug Smith
that sounds good. i may set my truck up like that
RonA
09-04-2007 11:09 AM
sway825
12-08-2004 10:21 PM
fitzer
01-31-2004 11:20 PM
HOHN
36
01-22-2004 11:14 AM
BAD HABIT
10-25-2003 11:52 PM
Quick Reply: mach injectors
