Lowering truck 2" out back
Old 04-02-2007, 05:53 AM
genros's Avatar
Has anyone done this? I hate the spacers up front (currently have) I'd like the truck to sit level so I am thinking it may be to my advantage to drop the truck two out back and go to stock ride height up front. Figure it may actually help the handleing and it would be a touch easier for my wife to get in and out of. My question is two part. If you did it, hwo did you do it? or what is the best way to drop it 2"?
Old 04-02-2007, 06:50 AM
BLACK PEARL's Avatar
I haven't done it, but this will help. http://www.klenger.net/dodge/lowerin...d/slide01.html
Old 04-02-2007, 07:04 AM
wrm
wrm's Avatar
GENROS this is done alot on trucks that pull goose neck or fith wheel trailers .its easy and does not efect the ride .i dont know if it gives 2" but it will give you the look you want.if you tow alot you might have to add air bags or timbrens to keep it from squating when loaded,because the truck will no longer be tail high.
Old 04-02-2007, 10:37 AM
JORDAN's Avatar
I did the rear lowering and it works, looks great. I just got new spring pack bolts ( you can reuse the u bolts ) lowered about 1 3/4" rides good and you have less of a chance of death wobble because you increase the caster of the front end by lowering the rear. it took me about 1.5 hours.
sqrl$$
13
07-27-2009 12:40 AM
nasty01cummims
06-30-2009 01:52 PM
PEAKSTRYDE
10-11-2007 04:20 PM
narlinghaus
16
11-02-2006 10:25 AM
Dieseldude4x4
10-17-2004 11:07 PM
Quick Reply: Lowering truck 2" out back
