Lowering truck 2" out back
Old Apr 2, 2007 | 05:53 AM
genros's Avatar
Has anyone done this? I hate the spacers up front (currently have) I'd like the truck to sit level so I am thinking it may be to my advantage to drop the truck two out back and go to stock ride height up front. Figure it may actually help the handleing and it would be a touch easier for my wife to get in and out of. My question is two part. If you did it, hwo did you do it? or what is the best way to drop it 2"?
Old Apr 2, 2007 | 06:50 AM
BLACK PEARL's Avatar
I haven't done it, but this will help. http://www.klenger.net/dodge/lowerin...d/slide01.html
Old Apr 2, 2007 | 07:04 AM
wrm's Avatar
wrm
GENROS this is done alot on trucks that pull goose neck or fith wheel trailers .its easy and does not efect the ride .i dont know if it gives 2" but it will give you the look you want.if you tow alot you might have to add air bags or timbrens to keep it from squating when loaded,because the truck will no longer be tail high.
Old Apr 2, 2007 | 10:37 AM
JORDAN's Avatar
I did the rear lowering and it works, looks great. I just got new spring pack bolts ( you can reuse the u bolts ) lowered about 1 3/4" rides good and you have less of a chance of death wobble because you increase the caster of the front end by lowering the rear. it took me about 1.5 hours.
sqrl$$
13
Jul 27, 2009 12:40 AM
nasty01cummims
Jun 30, 2009 01:52 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
narlinghaus
16
Nov 2, 2006 10:25 AM
Dieseldude4x4
Oct 17, 2004 11:07 PM
