How loud will it be???
Old 04-06-2006, 10:03 AM
krazykarl's Avatar
I am still debating removing the slincer ring from my turbo. Before I decide, I would like to know just how much more turbo noise should I expect upon removal? Twice as loud, three times as loud compared to stock????
Old 04-06-2006, 10:24 AM
Sea:\>Drive's Avatar
I was fooling around in the driveway the other day and took mine out to see. I would say about twice as loud. I notice the noise at much lower boost numbers now. Try it and see if you like it. It takes 5 minutes to remove it or put it back (if you don't like it).
Old 04-06-2006, 11:29 AM
krazykarl's Avatar
How hard would it be to put it back in? Would I need special pliers to compress the snap ring?
Old 04-06-2006, 12:51 PM
White00's Avatar
It's easy in easy out with a couple of small flat screwdrivers. Just walk it around slowly.
ADAM
Old 04-06-2006, 03:23 PM
krazykarl's Avatar
How obnoxious would it be on a long trip at hwy speeds from Oregon to Indiana?
Old 04-06-2006, 03:38 PM
Cummins Freak's Avatar
do you still have the stock air box because if you do then no worries wont be that loud and will not bother yu that much air intake you'll notice it but you'll get used to it fast
Old 04-06-2006, 03:51 PM
That would be up to you whether it would bother you. I would guess NO, but I just crank up the tunes if I get tired of hearing the whistle...
Old 04-06-2006, 04:00 PM
doomgaze's Avatar
I noticed the whistle a lot more when I took the ring out of my 05. On my 01 I couldn't really tell much of a difference. I don't even know if I would call it twice as loud with the stock air box. However, with the aFe she sings pretty good.
Old 04-06-2006, 04:46 PM
krazykarl's Avatar
I don't have the stock air box anymore as I went the BHAF route.
Old 04-06-2006, 04:51 PM
Truckman's Avatar
Question I have a question
Where is this ring?? Is it in the very Inlet of the turbo housing? I have been searching for a photo of it in this forum.
Bob
Old 04-06-2006, 05:01 PM
dodgeguy71's Avatar
Mine is much louder with just the BHAF, I tried several times to remove the silencer ring but have not been able to....but with the whistle I am hearing through the BHAF is fine for me. I guess like someone else said, pop it out and take it around the block and see what ya think.
Old 04-06-2006, 05:12 PM
Truckman's Avatar
Never Mind
Bob
Never Mind it is what I thought it was ,,, I have a housing that already has it remover,,
Old 04-06-2006, 06:45 PM
Willy91's Avatar
IMO the silencer ring is not that loud, and I really liked the sound when I had it. Now if you want some major turbo noise get a set of twins.
ROCKNRAM
23
09-16-2003 08:50 AM
dieselcrazy
04-01-2003 07:35 AM
adgr71
25
01-27-2003 02:11 PM
B-Peterson
20
12-04-2002 07:03 AM
Sean S
20
11-16-2002 02:45 PM
Quick Reply: How loud will it be???
