Loss of Power
Old 04-17-2006, 03:57 PM
Ghost Truck's Avatar
Loss of Power
I own a 2002 Dodge Ram 2500 5.9L Disel. I have a K&N Air Filter attached.
My problem is between 1500 to 1750 RPM the truck will lose power sometime. Basically, no matter how much I press the accelator the truck does not increase in speed. Which sucks when going up hill because now I lose speed. Sometimes if I down shift, the power comes back and I can accelerate. This happenes more frequently as the tank goes empty.
Old 04-17-2006, 04:01 PM
P.J
P.J's Avatar
You're not going to like the answers.
Do a search for "Dead Pedal" it can be one of two things causing your problem, more than likely you have a failing injector pump. ($)
You can check for any codes your truck may have by following the instructions in the tech facts section up top there.
Old 04-17-2006, 05:22 PM
nitrousn's Avatar
You should check the boost pressure. If your waste gate is stuck and you are getting overboost the sensor will relay that to the computer and the computer will start to de-fuel the motor. My truck will do that. Its ok when i am chipped/programed because of the boost fooler. Anything over 22 psi and it will start to de-fuel.
Old 04-17-2006, 05:28 PM
P.J
P.J's Avatar
The thing that lead to me tend to think VP44 is the "sometimes when I.."
Old 04-17-2006, 05:33 PM
Registered
blackdiesel's Avatar
pj's probley right . Check the codes 0216 is the bad one could be a 0122 or 0123 are apps, their not that much better
Old 04-18-2006, 12:14 PM
RowJ's Avatar
Check for codes... and maybe reset your APPS. Always start with easiest & free stuff first, IMO.
APPS reset is also in "tech facts" section... but leave batteries unhooked for 2 hr min... not the 30 min suggested!
Good luck - RJ
RHC
08-12-2019 03:32 PM
tntk9
11-20-2012 07:09 PM
cbrxxtreme
24
07-17-2008 03:30 PM
Ranger 2/75
03-16-2006 05:07 PM
jdcott1
10-20-2002 11:48 PM
Quick Reply: Loss of Power
