Lock up tranny or 89-91% converter
Old 12-20-2006, 06:10 PM
Mike T.'s Avatar
Question Lock up tranny or 89-91% converter
I know a lot of guys on this forum have gone to better torque converters to get better results from their trannys. I'm just wondering why more haven't converted to a 618 or a lock up . I know that our trucks aren't computer controlled, but can't you operate a lock up tranny with a switch? I'm going to do one or the other next year and I'm wondering what the best option would be.
Old 12-20-2006, 08:07 PM
Ilikebikes's Avatar
I know that there are a few more things to do this swap than just wiring up a new converter. You will need a new trans adaptor, a tranny designed for lockup (I think, maybe someone can chime in on this) and you may need to shorten the driveline. Not to mention the price of good, lockup converters for high horse applications ($1000+).
Old 12-20-2006, 08:17 PM
1st Generation Admin
BC847's Avatar
Don't forget the high-dollar billet input shafts (the 518 non-lockup's are solid) to go with that $1000 TQ.
Old 12-20-2006, 09:53 PM
sdstriper's Avatar
Here's what I know. You need a 47RH transmission and a lock-up torque converter, engine to transmission adapter and starter from a 94-95 CTD. Then find a way to controll lock-up and OD using a (mechanical - hydraulic - electronic) speed sensor and a (vacuum - electronic) throttle position sensor to control the overdrive and torque converter lock-up usually controlled by the computer using vacuum and oil pressure switch's.
Old 12-21-2006, 05:51 AM
Mike T.'s Avatar
My tranny guy said that he could turn my 518 into a lockup for about $1800. Maybe I should check into it more and see if this tranny guy really knows what he's talking about.
Old 12-21-2006, 06:08 AM
JD730's Avatar
Stock input shafts are not high dollar items. Billet shafts are a bit pricey though. And if you going to be throwing some fuel at it, those triple disc Gorenend converters are worth every penny.
Read this out of the sticky if you haven't already, I described the whole process and what needs and doesn't need to be done.
https://www.dieseltruckresource.com/...d.php?t=114702
Old 12-21-2006, 07:27 AM
Mike T.'s Avatar
Is it worth going to a lock up or just get a real good converter like Gorenend and other mod's. Would there be that big of a difference of getting power to the ground and fuel economy.
Thanks guys for the help.
Old 12-21-2006, 10:45 AM
loch's Avatar
Theres a shop in Dallas that builds tranny's that can deal with our HP and TQ, the cost is 2500 with a converter. they convert the 727 to a lock up and o/d. The only downside is having to figure a way to control the o/d and LU. I didnt post link cause they arent an advertiser here, feel free pm me.
Black Dog
12-03-2009 08:18 PM
90dodge
05-25-2007 10:50 PM
mr T
21
06-01-2005 08:48 AM
Nuttymopar
09-02-2004 07:39 AM
damon_achey
06-07-2004 03:33 PM
Quick Reply: Lock up tranny or 89-91% converter
