Little Injector input please
Old 02-25-2008, 06:24 PM
rootremblay's Avatar
By looking at my sig what injectors would yall recommend? I haul 6,000 lbs twice a month and live in Florida. Any advice or experiences would be awesome. What kind of power gains could be expected to the ground?
Old 02-25-2008, 08:42 PM
dzlfarmboy's Avatar
You'd prob like a Set of DDP 3' if you tow alot or some 4's if you have a valet switch on the truck.
Old 02-25-2008, 10:01 PM
psd tuner's Avatar
well i would go with a 100 hp injector. i dont know a good brand with the 12v but for the cheaps on the 24v the edge jammers is a good way to go.
Old 02-25-2008, 10:34 PM
Purplezr2's Avatar
Whats cheap for a set of jammers.
Old 02-25-2008, 10:38 PM
psd tuner's Avatar
i put the nozzles on mine, i really like them EXCEPT the lopey idle. their really good for $230. but they dont offer them for 12v
dzlfarmboy's Avatar
The Nozzles are offered from around $190--$290
Old 02-25-2008, 11:05 PM
The Guru
Mike Holmen's Avatar
Whats your end goals? Is money tight? the 370 cummins is pretty cheap and you can make a ton of power with them. Another good stock injector is the stock 215. To make more power you need to get you pump worked abit. I've heard trucks making 500 rwhp with 215 injectors. It just takes the right tuning/tweaking the pump. I'm not a P pump guys but there lots of stuff available. If you want a better injector and have some $$$, go with dynomite or formula. For trucks under 600rwhp, stock injectors will do the job. Its just easier to make abit more power and less smoke with an EDM injector.
Old 02-25-2008, 11:38 PM
thewished's Avatar
I'd put a plate back in, #4 or a 0 plate if you want cheap and some ddp3's. Just my 2 pennies
Old 02-26-2008, 04:40 AM
thanks for the help
Nate-03 D
16
02-13-2011 07:56 PM
450rRacer
12-10-2008 08:00 PM
Joe Diesel
11-12-2007 08:59 AM
scuzman00
03-07-2007 02:56 PM
Quick Reply: Little Injector input please
