Limited slip question
Old Sep 6, 2007 | 10:51 AM
scout98's Avatar
Did all trucks ship with some type / brand of limited slip differential?
The reason I am asking is I only have 1 wheel that spins when I lose traction. Is this just a sign that someone did not get the friction modifier correct at fluid change?
Old Sep 6, 2007 | 02:37 PM
SIXSLUG's Avatar
Not all are/were built with the LS rear end. The modifier could be missing/diluted or the friction pads may be worn out. A build sheet is available from any Dodge dealer with your vin # or look on the diff cover for a tag. It should also be listed in your glove box on the sticker in there
Old Sep 6, 2007 | 03:17 PM
Fishin2Deep4U's Avatar
I know mine did not comewith a LS. I added a Powr-Lok and couldn't be happier.
Dave
Old Sep 6, 2007 | 04:30 PM
motomac3's Avatar
should also tell you under the hood. pop the hood open and look up should be a trim tag up there. will tell you if its limited slip or not.
Old Sep 6, 2007 | 08:22 PM
2500superram's Avatar
my truck came loaded with all kinds of extra's,but HO 6spd and lsd
dieselcarpenter
Oct 28, 2007 06:39 PM
shawn085
Nov 21, 2005 12:46 PM
dkinzer
May 23, 2005 08:57 PM
Shaders 24v
Dec 8, 2003 12:29 AM
