Lets see your pedal pads...
Old 08-04-2011, 11:49 AM
Received 1,332 Likes on 862 Posts
I've been wanting to change/upgrade the pedal pads in the crewcab and was wondering what others have done. I really like the original mopar style ones with the stainless trim around them that came on a lot of the cars over the years. Like these...
Please post up some pics of your Clutch/Brake/Gas pedal pads.
Old 08-04-2011, 04:44 PM
sootnsmoke's Avatar
Mine are just the plain rubber with no trim but I like the stainless trim ones in your pic
Old 08-10-2011, 10:01 PM
BearKiller's Avatar
Can you post a side-by-side comparison between those and the stock ones ??
You have my interest.
Old 08-11-2011, 12:41 PM
feveree40's Avatar
my stock rubber ones are starting to develope their own metal trim ring if you know what i mean
Old 08-11-2011, 01:33 PM
james1's Avatar
Do you have a source for these pads? If so, part numbers?
Thanks,
Old 08-11-2011, 03:07 PM
Alright guys here's the skivvy on those pedals I posted up. Those are from a 68-70 Mopar B-body (charger, roadrunner, coronet, satellite).
Here are a couple pics comparing those pedals, to a set from a 1st gen.
The 1st Gen pedals are approx. 3 3/4" wide X 2 7/8" tall. The one in my pic...not from a B-body but the same basic pedal..is approx. 3 1/2" wide X 2 1/4" tall.
Now in these pics you can see the shape difference in the metal plate the pads mount over.
You would have to make new plates for the pads to mount on. As well as put a bend in them. Even the rubber pad is formed to match that curve.
So yes it's do-able, but might be a little bit of fab and welding required.
Old 08-11-2011, 08:40 PM
BearKiller's Avatar
Thanks, trashingsows; when I requested a picture, you went above and beyond the call.
Very helpful side-by-side comparisons.
I had sort of thought about some big after-market pads that I saw in someone's truck at the shop.
Before I decided I would try a set, they were hanging for sale everywhere; alas, now that I am slightly interested, I never see them.
The pads I am meaning were at least as large as the standard truck pads and had a chrome/stainless "grid" with thick treaded rubber poking through each opening in the grid.
If one opted to weld on steel plates for the pads you pictured, I bet the correct radius/arc could be found by cutting a section from a piece of large pipe.
Old 08-11-2011, 10:16 PM
I put my brake pad on the clutch pedal and clutch pad on the brake pedal. so now they're worn opposite and it confuses everyone lol
Old 08-11-2011, 10:43 PM
Onemoparnut's Avatar
I don't think it is everyone else that is confused
Old 08-11-2011, 10:48 PM
Bogie's Avatar
Mine are just covered in skateboard tape as I was missing one rubber pad.
Old 08-11-2011, 11:00 PM
BearKiller's Avatar
Good one.
Old 08-11-2011, 11:21 PM
jimlj's Avatar
I don't have the picture of my pedal pads, but I quite like them. To get them, you have to put your engine in a Ford though.
Old 08-11-2011, 11:55 PM
gadget.35-06's Avatar
I may have to try fabbing a set more like motocross foot pegs....that'd cure my sixteen-year-old daughter of that barefoot driving habit!
...funny, how when they turn sixteen and get a drivers' license they instantly turn into lawyers...
Old 08-12-2011, 12:26 AM
BearKiller's Avatar
Wrap 'em in bob-wire; that oughta keep her shoes on.
Old 08-16-2011, 11:23 AM
Well I finally found a pedal pad I liked for the clutch and brake.
Made by Mr. Gasket. They say thy are approx 4" wide X 2.5" high...so very close to the original pedal size.
Will update with info and pics when I get them.
Quick Reply: Lets see your pedal pads...
