leaky turbo line
Old 11-13-2010, 03:42 PM
19mike92's Avatar
leaky turbo line
the fitting going ino the block seems to leak quite a bit. is it possible to just replace the fitting or do u have to put on a whole new line? either way. how much will it cost me. please and thank you
Old 11-13-2010, 03:47 PM
1st Generation Admin
BC847's Avatar
Did you try tightening the hose clamp down there?
Old 11-13-2010, 03:49 PM
19mike92's Avatar
ya
but the fitting itself is shot. could be the o ring
Old 11-13-2010, 05:09 PM
92smokin blacky's Avatar
are you sure the hose isn't split or the hose clamp isn't loose? mine was leaking at the same place and it looked like it was coming from the fitting, but my hose was split open on the backside where i couldn't see it... oh and 7/8" oil hose is a little harder to find.
I think that fitting is pressed into the block from what i've heard?
Old 11-13-2010, 05:21 PM
BC847's Avatar
That is correct. It's simply a single piece, thinwall steel tube, press-fit into the block. (And that boy's in there like a hair in a biscuit).
RussianVolk
06-29-2010 01:13 AM
schoust
07-21-2007 08:14 PM
harleydodge
05-09-2007 07:49 PM
hotmopr
06-29-2006 10:22 PM
Quick Reply: leaky turbo line
