Leaking fuel screw
Old Dec 20, 2011 | 10:20 PM
bulltamer's Avatar
Leaking fuel screw
I helped my buddy out with his new ride. It's a 91 reg cab 2wd daully automatic with 3.07s I turned the fuel pin and cranked down the star wheel. Then I took out the fuel screw busted off the collar and put it back in. Turned it bout 2 turns and it's leaking from the screw.
What's wrong? How do I fix it?
Old Dec 20, 2011 | 11:00 PM
6BTchev86's Avatar
Guess the only thing I can think of Is that the threads got lightly damaged and fuel is seeping past them or did the brass washer seal that tightens up with the jamb-nut get forgotten? I have done many and never had this problem? Is it a slow leak or steady? Does the truck run like it should?
Old Dec 20, 2011 | 11:14 PM
bulltamer's Avatar
It runs wonderful and quick! It's faster than my 92. I might slip on another brass washer to see it it stops and it's kinda steady
Old Dec 20, 2011 | 11:22 PM
pulltilbroke's Avatar
Best Paint (Getrag category)
The washer on there isn't a sealing washer.
There is an O ring halfway down the screw, Replace it and you'll be good to go.
Old Dec 20, 2011 | 11:42 PM
bulltamer's Avatar
Pullitbroke where would I be able to get an o-ring at? Cummins or napa?
Old Dec 21, 2011 | 12:34 AM
Probably neither. Just go to your local pump shop.
Old Dec 21, 2011 | 05:57 AM
Bob Beauchaine's Avatar
bulltamer
I've got some extra "O" rings for the fuel screw - no charge. If you would like a couple PM me with your address and I will mail them to you.
Bob
Old Dec 21, 2011 | 06:08 AM
Jim Lane's Avatar
Here I will explain it to you.
https://www.dieseltruckresource.com/...d.php?t=239076
Jim
Old Dec 21, 2011 | 06:54 AM
AUGIE DOG's Avatar
Jim I just read your procedure for replacing the o-ring and you mentioned take care rolling the o-ring onto the threads.I was thinking you are going to cleant the screw of any trash on it and after you do that could you put some duct tape around the threads slide the ring on, seat it and remove tape. Just a thought. It is still early in the morning so my brain functions better but declines as the day goes on! lolol
Old Dec 21, 2011 | 07:38 AM
Jim Lane's Avatar
That would work, so would a larger soda straw like the ones you get with a thick malt.
Jim
Jim Lane
Dec 19, 2017 09:55 AM
jmd4993
Jun 22, 2013 07:36 AM
m1guy
Apr 18, 2006 04:53 PM
loudcummmin
Oct 3, 2005 02:44 PM
